Dragon Box Chinese Phone Tool |
06-26-2014, 15:59 | #31 (permalink) |
Freak Poster Join Date: Feb 2010 Location: karachi pakistan
Member: 1237819 Status: Offline Sonork: [email protected] Thanks Meter: 148 | |
06-27-2014, 04:26 | #32 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | Quote:
06-27-2014, 06:25 | #34 (permalink) |
Junior Member Join Date: May 2014 Location: Sindh,Pakistan
Member: 2194003 Status: Offline Thanks Meter: 10 | Without box it is look like Demo version because just a "write flash" is disable if connected box so all works fine as full version having all options. But I'm still happy cause "format" and "write imei" working well. ;-) without Box :-) |
06-27-2014, 09:52 | #36 (permalink) |
Freak Poster Join Date: Nov 2009 Location: waiting for a ticket to ***
Member: 1172662 Status: Offline Sonork: 100.1625907 Thanks Meter: 9 | hello supporter team please solve my problem when i open the dragon software and try to connect it does not connect and hang the software even it does not close with alt,ctrl,dlt till restart but at this stage open another dragon software it connects and work as fine till i cant understand what is the problem my pc os is xp3 and i also tried with adminstrator mode till same issue |
06-27-2014, 12:58 | #38 (permalink) |
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | This is dragon service busy and when software click the check box ,software first connect to dragon service or maybe is your internet slow just wait a second |
06-28-2014, 04:17 | #40 (permalink) | |
Read This Post | |
06-28-2014, 08:00 | #41 (permalink) |
Registered User Join Date: Jan 2012 Location: Above the earth
Member: 1711578 Status: Offline Sonork: 100.1606127 Thanks Meter: 51 | Please fix spreadtrum not detecting in com port but ok using usb port.some mobile have damage usb port and we cannot connect spreadtrum in com port .please fix this problem as soon as posible. |
06-29-2014, 22:51 | #43 (permalink) |
Freak Poster Join Date: Aug 2007 Location: jamaica
Member: 565786 Status: Offline Thanks Meter: 11 | error formatting 6572 mtk fone >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:0E_8D PID:20_00 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM353 Driver Name->>>PreLoader USB VCOM Port Mobile Connection Success... CPU_ID:MT6572 Hardware Version:8A00 Software Version:CA01 >>> Downloading First Boot... >>> Authenticating BOOT... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWN ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN ================EMMC Flash Info================= Flash ID:0x90014A483447316448609A3307CA08D Flash Name:0x484A019064314734 Get Mobile Flash Size:0xE7000000 >>> Formatting... Formatting Start Adress(Hex): 0x44040000 Size(Hex): 0x44B00000 >>> Return DATA Error!!! |
06-30-2014, 05:57 | #44 (permalink) | |
07-02-2014, 02:33 | #45 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: philippines
Member: 448980 Status: Offline Thanks Meter: 136 | User Report: SPD 6530A alive phone tested after format dead... Quote:
