Dragon Box Chinese Phone Tool |
12-16-2013, 16:22 | #1 (permalink) |
Junior Member Join Date: Aug 2007
Member: 566311 Status: Offline Thanks Meter: 3 | Help me "error" read dragon 6820 VCC Pin: GND Pin:7, Signal Pin:1, 3, 4, 5, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:4 D-:3 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM41 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:115200 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 >>> Reading Flash... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... |
01-10-2014, 14:48 | #4 (permalink) |
Junior Member Join Date: Sep 2008
Member: 855787 Status: Offline Thanks Meter: 0 | i have same problem with SPD 6820 >> Getting Mobile Connection Info... VCC Pin: GND Pin:20, Signal Pin:21, 22, 23, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:22 D-:23 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM16 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:1843200 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Reading Flash... Error:Receive Data 0x7E Error... Error:Receive Data 0x7E Error... |
01-10-2014, 16:28 | #5 (permalink) |
Member: 566311 Status: Offline Thanks Meter: 3 | LG X350 MTK 6236 error in "format" Detecting COM PortCOM48 Mobile Connection Success... CPU_ID:MT6236 Hardware Version:8A03 Software Version:8A00 Initialization RAM Error,FUNC boot_init_1 >>> Return DATA Error!!! |
