Dragon Box Chinese Phone Tool |
07-15-2013, 07:35 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Hepl me after formating code not removed >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, 6, 7, 8, 9, 11, 13, 15, 17, 19, 21, 23, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM28 Mobile Connection Success... CPU_ID:MT6250 Hardware Version:8B00 Software Version:CA05 >>> Downloading First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x01000000 -> 16M Flash ID:0x00C8006000180000 Flash Name:SF_GD25LQ128 ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x00CE0000 Size(Hex): 0x00320000 >>> Formatting... All Done... |
07-15-2013, 08:09 | #7 (permalink) |
Member: 1771086 Status: Offline Thanks Meter: 2,410 | old v 2-13 is tha very best now updeat not good in 2.13v clack unlock then show cod my problem solved Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0050 |
The Following User Says Thank You to fahad ali khan For This Useful Post: |
07-15-2013, 11:12 | #9 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Bro, if format not work for you, then, read the flash file and read the security code. Still, not works, flash the cell phone with working firmware. BR Dipendra Pathak |
