Dragon Box Chinese Phone Tool |
11-08-2011, 10:04 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Kiev, Ukraine Age: 39
Member: 88304 Status: Offline Thanks Meter: 9 | how to flash mstar based phone |
11-08-2011, 15:02 | #2 (permalink) |
Member: 88304 Status: Offline Thanks Meter: 9 | support how many posts should i write for you to notice me? i wrote 4 times already and still no answer. please provide step by step manual for connecting and pinfinding mstar phones, i do not understand your video manual, it does not explain nothing at all. thanks in advance |
11-09-2011, 07:59 | #3 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
11-09-2011, 14:47 | #4 (permalink) |
Member: 88304 Status: Offline Thanks Meter: 9 | i saw that video million times, it explains NOTHING. i read info using gpg freeware, "external connector info" using p-10c connector and tv 6700 rh-13 mobile. it shows as following: Charge termipoint detection guide 1ЈєPlease analyse the External connector first(connect it with the crocodile clips) 2ЈєAfter the analysis, remove the clips and fix the battery in 3ЈєSet the charge pin according to the short-circuit pin, and pay attention to the phone info. It is analyzing the External connector, please wait... ******Auto analysis has been completed****** VCC= GND=2, Signal=1,4,5,6,7,8,9,10, NC=3,11,12,13,14,15,16,17,18,19,20,21,22,23,24, Important: Most charge termipoints are the pins in short. Don't go on the next step until you have fixed the battery in. >>>******************************************** next i run "definition set" and press voltage, on turned off phone. only 10pin shows 0.1v, all other are 0.0. on turned ON phone there are lots of signal pins how to know which is rx-tx, which is usb d-, usb d+? how to set up correct pinout? i tried in different combinations, only Initializing... DA_LIB_VER_3.6.7.1 Detecting USB device... please help |
11-10-2011, 12:53 | #5 (permalink) |
Member: 88304 Status: Offline Thanks Meter: 9 | at last i have found correct pinout, now phone detects by system and new device h: appears. but dragon does not detect it, it only shows Initializing... DA_LIB_VER_3.6.7.1 Detecting USB device... and nothing more. how to solve that? i disassembled the phone, cpu is msw8533c, it is supported by dragon. how to connect? |
11-14-2011, 16:51 | #9 (permalink) |
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Open your freeware software 1st_Step.....Open scan option then connect your mobile with cable. 2nd_step.....select your phone chip mtk,mstar etc.(if you don't know that what kind of chip is this ,then select auto & scan it.) 3rd_step.....After this, It will sens your device & when your mobile become connect it will tell you the rx,tx,vcc & also gnd. Now you can set it manually at definition set. WITH BEST REGARDS |
11-22-2011, 00:06 | #12 (permalink) |
Member: 88304 Status: Offline Thanks Meter: 9 | how does it can help? i have found working pinout, phone is detected by windows, my computer detects new drive h:. but software DOES NOT read flash, info, it does not connect to phone. just hangs on this: Initializing... DA_LIB_VER_3.6.7.1 Detecting USB device... how to make it work? do i have to install some special driver instead of driver installed by windows? dragon team, i am really tired for asking help for 2 MONTH and still no answer and no solution. you do not respect your customers? |
11-22-2011, 03:27 | #13 (permalink) |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | For mstar You need download gpgdragon last Firmware GPGDragon Firmware 1.58E.rar is easy do it run gpgdragon Ver 2.10 select CPU to Mstar Select Boot to 8533C connect Mobile with Dragon cable also Box to Mobile bettery Pin connect click Start Button Software tip You hold the Power key(Please Don't hold it) cause is Before old firmware need,but after 1.58Firmware no need ******Auto analysis has been completed****** VCC= GND=2, Signal=1,4,5,6,7,8,9,10, NC=3,11,12,13,14,15,16,17,18,19,20,21,22,23,24, Important: Most charge termipoints are the pins in short. Don't go on the next step until you have fixed the battery in. >>>******************************************** I has See Your Info I think you use P-10C cable( Please check ,if P-10C can't Pinfind,then use the P-05A and try again) Holp It can help you fix Your promble for Me every day I has Face Mstar Mobile,And I can fix 90% it gpgdragon and 100% I can pinfind it |
11-24-2011, 11:04 | #14 (permalink) |
Member: 88304 Status: Offline Thanks Meter: 9 | i HAVE FOUND PINOUT ALREADY! my pc detects phone and installs driver, i have new drive H: after it. but DRAGON DOES NOT CONNECT TO IT. do i explain clearly? |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
