Dragon Box Chinese Phone Tool |
11-14-2013, 15:57 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | how to reset tracker / antitheft code???? VCC Pin:22, GND Pin:10, Signal Pin:8, 9, 17, 19, 21, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:9 RXD:8 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6235 Hardware Version:8A04 Software Version:8A01 >>> Downloading First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0001227E22232201 Flash Name:NOR_S29GL512N_T ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN All Done... FORMAT ERROR >>> Getting Mobile Connection Info... VCC Pin:22, GND Pin:10, Signal Pin:8, 9, 17, 19, 21, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:9 RXD:8 >>> Please Hold the Power key... >>> Connecting Mobile... CPU_ID:MT6235 Hardware Version:8A04 Software Version:8A01 >>> Downloading First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... ================NOR Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0001227E22232201 Flash Name:NOR_S29GL512N_T ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x0000000000000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x00000000 Size(Hex): 0x00000000 Formatting Failed... >>> Return DATA Error!!! when i start set set ask 4 digit code Last edited by omkarvitekar; 11-14-2013 at 16:07. |
11-14-2013, 18:34 | #3 (permalink) |
Insane Poster Join Date: Apr 2008 Location: ph
Member: 762556 Status: Offline Sonork: 100.1649174 Thanks Meter: 11 | hi! if you are first time in hand that mt6235 handset, better to read and back it up.. and use tools tab and tick MTK read privacy by file.. but for shortcut solution use format option tested many times without damage imei even nand flash .. if you use com try direct pinout rx tx to board.. Last edited by Anot_rf; 11-14-2013 at 18:40. |
