Dragon Box Chinese Phone Tool |
07-12-2013, 02:59 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: china Age: 35
Member: 1428349 Status: Offline Sonork: 100.1597111 Thanks Meter: 13,139 | not need root,just select the CPU to spreadtrum select Mobile CPU Type to 6820 Select Write IMEI and Click Start Button,then it will read the Mobile ORG IMEI then input the New IMEI and Write |
The Following 2 Users Say Thank You to GPGDragon Help For This Useful Post: |
07-22-2013, 05:15 | #6 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Follow the method to repair IMEI Bro How to Repair Android IMEI with the help of Dragon Box 1)Run Dragon Software 2) Choose the Dragon Box Port and Click on "CheckBox" 3) Un-check 'Scan Pinout" 4) Choose "Write_IMEI" 5) Choose "USB" port 6) Tick "Android IMEI" 7) Click on "Start" 8) Now, Take out the battery and re-put it again in your device 9) Connect USB Cable Mobile to Computer (If Boot Key Needed, then, first Hold On BOOT Key and insert data cable to the computer) 10) Let it be install required Driver 11) After installation driver, IMEI Opetion highlight with Yellow Colour 12) CLick On "Read_IMEI" to read device IMEI 13) Now, Choose Required IMEI that you want to write 14) Click on "Write_IMEI" 15) Check your device's IMEI. That's All Necessary Things you may need: 1. Driver from here: usb_acer_1.0_a41j_a - Download - 4shared 2. Android Fix driver by Microsoft: spd android fix file - Download - 4shared 3. Full charget Battery 4. USB Cable (Not Dragon Jig) BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
