Dragon Box Chinese Phone Tool |
09-06-2011, 10:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Mahi v2 format no service problem plz help me DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF006000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: Z101.XT5700.MAHI-V1.0-0630 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
09-06-2011, 10:49 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | First try imei change if still same problem so you need read NV file or full flash file from same working phone and write this phone |
09-06-2011, 11:47 | #6 (permalink) | |
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Quote:
Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... Failed to load boot... | |
09-06-2011, 13:00 | #7 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
@ kabul.. no other solution only read nvram from working set nd write it to no service fone. 100% work for you!! your nvram with this Project ID: Z101.XT5700.MAHI-V1.0-0630 not found in any database.. pls wait for someone answer | |
11-04-2011, 15:41 | #11 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Check this file first read your phone Cnv file then write this... V2_MAHI_OK_GREEN.BOARD_CPU=MT6252_FLASH=Unknown Flash_Z101.XT5700.MAHI-V1.0-0630.cnv |
The Following User Says Thank You to rameez_gsm For This Useful Post: |
12-03-2012, 05:30 | #12 (permalink) |
Freak Poster Join Date: Mar 2012 Location: KPK Pakistan
Member: 1740432 Status: Offline Sonork: 100.1628012 Thanks Meter: 24 | MTK X8 Formate But no Signal .....Palzzzz help me Repier IME And no Service..... Initializing... DA_LIB_VER_4.3.6.8 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 353056525630922 IMEI 1 rebuild has been implemented: 353056398855234 Original IMEI 2= 353056644493715 IMEI 2 rebuild has been implemented: 353056525616293 Need to restart the phone to verify new imei. |
