Dragon Box Chinese Phone Tool |
04-02-2014, 07:19 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: ??????
Member: 446199 Status: Offline Thanks Meter: 40 | Micromax X272 after format dead & can't Flash [Answered] After format it not power on now Have backup When try to flash it shows >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, 8, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM6 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info CPU Name:6530 Flash ID:0xC225370000000000 Flash Name:SF_MX25U6435E Flash Size:0x00800000 -> 8M Baud Rate is Switched To:921600 >>> Writing Flash File... Full Flashing .. Error CODE:FF--> CMD_EERPR --> UNKNOWN |
04-02-2014, 08:55 | #2 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Bro, write this file, I hope 100% wake up Quote:
http://www.mediafire.com/download/9g...GD27LQ64++x272 and Micromax-X272 Flash File(1) - Download - 4shared - Mosh@rof Telecom Any Provlem Tel Me...+8801744-201111..+8801816926000.. .Thanks... Sometimes you need to repair IMEI also. Don't forget to post the screen short. Good Luck BR Dipendra Pathka | |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
04-02-2014, 11:34 | #4 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | x272 i also have micromaxx 272 after format with dragon dead no solution frm team always format success but in write flash error with loader showing nv failed plz help i have 2 set if have any solution plz tell |
04-02-2014, 11:48 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Follow the method: 1. Open the Dragon box. 2. Connect the Dragon box 3. Connect the Device with Jig 4. Connect power from the Jig Vcc and Gnd to the Mobile Battery Pin 5. Choose the SPD tab 6. Choose "Write File" 7. Choose the working file 8. Choose boot "6531A" 9. Choose "USB" (not COM) 10. Click on "Start" 11 Wait until write the firmware. Good Luck Note: do not spam here. Because we have tested many more 6531A devices. BR Dipendra Pathak |
04-02-2014, 13:31 | #6 (permalink) |
Member: 446199 Status: Offline Thanks Meter: 40 | Its still the same there is no change >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, 8, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM6 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info CPU Name:6530 Flash ID:0xC225370000000000 Flash Name:SF_MX25U6435E Flash Size:0x00800000 -> 8M Baud Rate is Switched To:921600 >>> Writing Flash File... Full Flashing .. Error CODE:FF--> CMD_EERPR --> UNKNOWN The phones problem was Code it was fully working power on & all no problem Connected to Dragon box When check info all OK Read Flash backup all ok Formating shows done all ok but not power on Flashing the Backed up file Or any file shows the error Error CODE:FF--> CMD_EERPR --> UNKNOWN (The Customer is getting frustrated) i had these kind of problem before but after flashing the backup file it will be back to normal Need solid solution as soon as possible |
04-03-2014, 19:38 | #8 (permalink) | |
Freak Poster Join Date: Dec 2010
Member: 1477125 Status: Offline Thanks Meter: 88 | Quote:
WHY YOU FORMAT THE SET BRO THIS PHONE HAVE DULE FLASH IC 1. DOWNLOAD FILE AND FLASHER FROM HERE X272 by GsmHosting S. - 4shared 2. SELECT SPD 6530 IN DRAGON AND ONLY READ INFO 3.REMOVE A POWER CLIP RED OR BLACK 4. RUN FLASHER 5. SELECT PAC FLASH FILE IN DIR OF FLASH FILE 6. NOW PRESS START BUTTEN IN FLASHER 7 JUST PUT THE DRAGON POWER CABLE TO PHONE FLASHING START AFTER FLASHING FINISH PHONE WILL ALIVE IF FACE ANY PROBLEM CONNECT ME ON YAHOO YAHOO ID [email protected] BEST OF LUCK BRO | |
04-03-2014, 23:46 | #9 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Pakistan & UAE (Dubai) Age: 34
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | Its Drivers Problem nothing els uninstal all old drivers instal new drivers from dragon new ver 3.44 then check and post result |
04-04-2014, 06:09 | #10 (permalink) |
Member: 446199 Status: Offline Thanks Meter: 40 | (THX imranidrisi for the reply) Will try it by ur way but the file is 4mb its backed up file is 8mb I have seen this on other post the flash file name & size is different |
04-04-2014, 13:47 | #12 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | If you think we are misleading you, then, do not ask help with us brother. we are not here for misleading. Supporter says "Answered" means he has just answered. Now, I need Open your device, Take picture of the device and Post here....I think this device has TWO CPU. BR Dipendra Pathak |
04-04-2014, 14:43 | #13 (permalink) |
Member: 1526738 Status: Offline Sonork: 100.1607644 Thanks Meter: 6,688 | BE COOL my dear if you face again this problem after instal new drivers then post here detail we try to help you other wise conntect me on sonork no need use these type of language which any one hurt so next time talk in limit |
04-04-2014, 18:28 | #15 (permalink) |
Member: 446199 Status: Offline Thanks Meter: 40 | "If you think we are misleading you, then, do not ask help with us brother" Product supporters r supposed to help & stay behind their product Here is my other post http://forum.gsmhosting.com/vbb/f646...d-how-1784782/ http://forum.gsmhosting.com/vbb/f646...-when-1682861/ http://forum.gsmhosting.com/vbb/f646...error-1600347/ Some of my older post not solved If it can or cant be done just say it For every Mobile Technician (or in any other field) they take care of their customer's FIRST If he or she is a valued Customer then there is no question y they keep coming back to fix their phone's This was my very highly valued customer (who brought in a locked working phone.... Locked by his kid while playing with it) Giving him a dead phone back is not what he or i expected I am not angry (not getting solid answers fast enough ) Even the guy who answered is not a product supporter & is given to do by other software not by "GPG DRAGON" So there thats it i have given my solid reason I think i am done here |
