-   Dragon Box (http://forum.gsmhosting.com/vbb/f646/)
-   -   micromax x550 problem (http://forum.gsmhosting.com/vbb/f646/micromax-x550-problem-1312135/)
compue 07-20-2011 09:34
when i try to connect micromax x550 it show
Initializing...
DA_LIB_VER_3.4.1.2
It is sensing the pinout fast...
D-=3 D+=0
BOOT set failure, continue to scan...
Sense failure
since in this set * button not exist since it is touch phone, what is the solution to connect this phone ?
.::LUQMAN::. 07-20-2011 09:37
this is enough for this problem.i just request to gpg supporter to check and solve this problem for x550 or declare here that this model not supported.............straight answer is need
RIZWANJAT 07-20-2011 09:37
Not press * button you need press and hold on 0 button fro whole time
.::LUQMAN::. 07-20-2011 09:38
Originally Posted by rizwanjat (Post 7547139)
not press * button you need press and hold on 0 button fro whole time
great answer.........r u know this phone is touch phone......no keypad here
GPGDragon Help 07-20-2011 10:10
connect with my sonork,i can help you pinfind and boot,but flash need wait next new update
Faheem Anjum 07-20-2011 11:07
can you post here the chip info which flash chip inside the phone ?
siiss 07-20-2011 14:36
its micromax x550 qube chip is mstar
stacey-ann 07-20-2011 14:44
more info needed to solve your problem
like chip id
reason of phone either the phone drop or water damage,
post it here
and the status of the phone
::.HABIBRANA.:: 07-20-2011 15:07
Contact with me sonork 100.1592537 i will try to help you.
redrose2009 07-21-2011 06:14
Your cable may be fault
globalsolutions 12-17-2011 08:59
micromax x550 cube, the charging connector tracks have been spoiled, could any member give me the RX/TX pinout with image or diagram, it will be very helpful, thanks in advance.
Faheem Anjum 12-17-2011 12:19
Check other section dragon box not support 8533N chip yet
shafi_136 08-07-2012 08:35
micromax x550 print brakage on charjing conector
please help me anybody how to find rx tx pin.
Page generated in 0.28719 seconds with 5 queries
