Dragon Box Chinese Phone Tool |
10-12-2012, 13:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1689739 Status: Offline Sonork: 100.1608775 Thanks Meter: 164 | mobile dead healp me 2.09 mobile... htc rocka ((spd 6800h)) PROBLEM:: no problem this is work good condition just for the TEST but mobile is dead read info ok >>> Getting Mobile Connection Info... VCC Pin:7, GND Pin:2, Signal Pin:1, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:6 D-:8 >>> Scanning SCI Port... Detecting SCI Port :COM15 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD76 Flash Size:04000000->64M Flash Name:HY27XS08121M Factory Flash:NAND_HYNIX All Done... read flash ok >>> Getting Mobile Connection Info... VCC Pin:7, GND Pin:2, Signal Pin:1, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:6 D-:8 >>> Scanning SCI Port... Detecting SCI Port :COM15 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD76 Flash Size:04000000->64M Flash Name:HY27XS08121M Factory Flash:NAND_HYNIX >>> Reading Flash... Reading Flash Done... write flash ok >>> Getting Mobile Connection Info... VCC Pin:7, GND Pin:2, Signal Pin:1, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 18, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:6 D-:8 >>> Scanning SCI Port... Detecting SCI Port :COM15 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD76 Flash Size:04000000->64M Flash Name:HY27XS08121M Factory Flash:NAND_HYNIX >>> Writing Flash File... Writing NV To Flash ... Writing BOOT_LOADER To Flash... Writing KERNEL_IMG To Flash... Writing USER_IMG To Flash... Software Auto adjust "USER" Size: 0x00F7F840 Write MMIRES To Flash... All Done... my set 100%ok but write flash mobile no on |
10-12-2012, 13:15 | #2 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | bro after did u format.if u not format after writeflash plz format an d check |
The Following User Says Thank You to ihsan.khan.gsm For This Useful Post: |
