mstar driver not found please help me gpgdragon team >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Mstar Driver Not Found!!! >>> Return DATA Error!!! i did install new windows xp but the problem is still same please help me thanks in advance |
1st try with press and hold power button until all process not complete & Install Update Driver. BR. Arsalan gsm2000. |
Have a proper look here and you will get all information about it... All drivers you will get from here.. http://forum.gsmhosting.com/vbb/f646...ution-1577308/ If you still get any problem then knock me at sonork... :) |
mstar driver not found please help me gpgdragon team >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Mstar Driver Not Found!!! >>> Return DATA Error!!! i did install new windows xp but the problem is still same please help me thanks in advance Report Post Reply With Quote |
