Dragon Box Chinese Phone Tool |
12-29-2012, 11:01 | #1 (permalink) |
Insane Poster Join Date: May 2007
Member: 505972 Status: Offline Thanks Meter: 10 | mstar driver not found please help me gpgdragon team VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Mstar Driver Not Found!!! >>> Return DATA Error!!! i did install new windows xp but the problem is still same please help me thanks in advance |
12-29-2012, 15:28 | #2 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
1st try with press and hold power button until all process not complete & Install Update Driver. BR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
12-29-2012, 15:36 | #3 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: JHELUM,PAKISTAN
Member: 1082557 Status: Offline Sonork: 100.1611230 Thanks Meter: 199 | Quote:
Have a proper look here and you will get all information about it... All drivers you will get from here.. http://forum.gsmhosting.com/vbb/f646...ution-1577308/ If you still get any problem then knock me at sonork... | |
10-23-2014, 12:39 | #4 (permalink) |
Junior Member Join Date: May 2013 Location: Gazipur , Bangladesh
Member: 1948740 Status: Offline Sonork: 100.1645832 Thanks Meter: 13 | mstar driver not found please help me gpgdragon team >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Searching Mstar Driver... For Mstar 853XB CPU;You need Hold Down the Power KEY. Mstar Driver Not Found!!! >>> Return DATA Error!!! i did install new windows xp but the problem is still same please help me thanks in advance Report Post Reply With Quote |
