01-28-2013, 17:57
#1 (permalink)
| No Life Poster
Member: 1076772
Sonork: 100.1601881 Thanks: 1,532
| MTK Chip's Info. Writing Flash. Format Read (IMEI Write (IMEI) BY GPGDragon_3.18a CHINA NOKIA A_2655+ Get Project ID from phone...
Project ID: ZS516B_044A_V1_0_2 ==NOR Flash Info >>> Writing Flash ... BUT PHONE RESTART >>> Formatting... Phone is All Ok imei invelid >>> Reading Mobile (IMEI)... >>> Writeing (IMEI) to Mobile... Quote:
| Quote: Initializing...
DA_LIB_VER_4.3.6.8
It is sensing the pinout fast,please hold on the phone Power key
RXD=1 TXD=6
Connecting...Please hold on the POWER key until the red gauge is going...
Any errors please select another boot and try again.
BB:6252, HardwareVer:8B00, SoftwareVer:CE00
Loading boot...
INT_SYSRAM_BOOT test completed.
Loading boot...
Boot2 test completed.
Nor Flash ID: 00EF006000170000
Nand Flash ID: 0000000000000000
Read Hardware Information is done.
Config EMI(Nor Flash only)...
H/W detection ok.
>>> Getting Mobile Connection Info...
VCC Pin:
GND Pin:
Signal Pin:1, 6,
>>> Scanning Mobile PinOut...
>>> Please Hold the Power key...
Get Mobile PinOut: TXD:6 RXD:1
>>> Connecting Mobile...
CPU_ID:MT6250
Hardware Version:8B00
Software Version:CE00
>>> Downloading First Boot...
>>> Downloading Second Boot...
>>> Authenticating BOOT...
BOOT Validation Success...
================NOR Flash Info=================
Flash Size:0x00800000 -> 8M
Flash ID:0x00EF006000170000
Flash Name:SF_W25Q64DW
================NAND Flash Info=================
Flash Size:0x00000000 -> 0M
Flash ID:0x0000000000000000
Flash Name:UNKNOWNUNKNOWN
All Done... >>> Writing Flash ...
VCC Pin:
GND Pin:
Signal Pin:1, 6,
CPU_ID:MT6250
>>> Switching Baud Rate...
Baud Rate is Switched To:921600
>>> Erasing Flash Now....
>>> Writing Flash File...
All Done... BUT PHONE RESTART >>> Formatting...
VCC Pin:
GND Pin:
Signal Pin:1, 6,
CPU_ID:MT6250
Formatting Start Adress(Hex): 0x00768000 Size(Hex): 0x00098000
>>> Formatting...
All Done... Phone is All Ok imei invalid
VCC Pin:
GND Pin:
Signal Pin:1, 6,
"IMEI "options color to yellow then you can ReWrite IMEI...
IMEI 1:358688000000158
IMEI 2:358688000000158 >>> Writeing (IMEI) to Mobile...
VCC Pin:
GND Pin:
Signal Pin:1, 6,
IMEI 1:017117851888888
IMEI 2:019116497177777
Write (IMEI_1) to Mobile Doe..
Write (IMEI_2) to Mobile Done.. | |
