Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Dragon Box
Dragon Box Chinese Phone Tool
Old 07-15-2012, 07:31   #1 (permalink)
Member: 1712692
nokia b200 sc6600l7 after format dead :(
hi gpgdragon support
i get one phone for format .
i format phone and success to fomart and phone dead.
i cant write back up file too hang on 49% . phone just need format for unlock and reset all setting and now with gpg dragon deaded.
please help me
Old 07-15-2012, 08:31   #2 (permalink)
Member: 1652269
ues baudrate 115200 my porb some is done
The Following User Says Thank You to Adnan_shahzad For This Useful Post:
Old 07-15-2012, 09:06   #3 (permalink)
Member: 1712692
i set 115200 and not solved !
Old 07-15-2012, 09:50   #4 (permalink)
dil_PAKISTANI's Avatar
Member: 515273
Sonork: 100.1573940
Write this file and use baudrate 115200
CPU SC6600L7 Flash NOR_ST_M58WR064KT.rar
The Following User Says Thank You to dil_PAKISTANI For This Useful Post:
Old 07-15-2012, 09:54   #5 (permalink)
luckymobile jalandhar's Avatar
Member: 1002949
Sonork: 100.1582346
Spreadtrum l7 not supported for format only solution flash but do make backup first
The Following User Says Thank You to luckymobile jalandhar For This Useful Post:
Old 07-15-2012, 10:02   #6 (permalink)
Member: 1712692
again on 49% hanged bro.
Old 07-15-2012, 13:35   #7 (permalink)
Member: 1712692
gpgdragon support ?!?!?!
Old 07-15-2012, 14:39   #8 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Flash with the file (baud rate 11500) and post the result brother :
NOKIA_B200_3 SIM.rar
The Following User Says Thank You to Dipendra Pathak For This Useful Post:
Old 07-15-2012, 15:15   #9 (permalink)
Member: 1712692
thanks for your answer.
i flashed with your file and again on 49% failed.
Old 07-15-2012, 17:10   #10 (permalink)
Member: 1712692
Initializing...
DA_LIB_VER_4.3.6.8
It is sensing the pinout fast...
D-=4 D+=3
Searching commport...please wait...
Connecting...
Spd USB-to-Serial=COM17
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700900005A00_00
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 115200 is ok
Reading phone HW info...
Read info is done.
CPU: SC6600L7 Flash: NOR_ST_M58WR064KT
setting the Flash Parameters...
Settings have been completed!
Unlocking all blocks before program/erase...
Unlock Done.
Programming...
Compare Image: Enable
Error: Write Flash section
in 49%
Old 07-16-2012, 04:28   #11 (permalink)
Member: 747989
Sonork: 100.1593052
The file I have sent you 100% tested file.
Try to format mobile then flash with this file. If still not work. Might be hardware problem also (Flash IC) so Give a little bit hit on the CPU and try again.
Good Luck Brother.
Old 07-16-2012, 07:03   #12 (permalink)
Faheem Anjum's Avatar
Member: 399832
its have bugs will be resold in upcoming updates
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 07-16-2012, 09:07   #13 (permalink)
Member: 1712692
new version will be released in 1-2 day ?
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34115 seconds with 12 queries
