Dragon Box Chinese Phone Tool |
05-21-2013, 04:27 | #8 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Let me clear it to the users including you If software tells you NOR File Not Found, then, it is Nand. If software tells you Nand File Not Found, then, it is NOR. If software tells you NOR and Nand files Not Found, then, it is hardware problem = Re-hot CPU or Re-ball CPU and try again. For Example 1. Hardware Problem (Nor and Nand Flash id is 00000000) Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 2. Nand Flash ID not found (it is Nor because Nor id is 008981........) Nor Flash ID: 0089810300000000 Nand Flash ID: 0000000000000000 3. Nor Flash ID not found (it is Nand because Nand id is 005678........) Nor Flash ID: 0000000000000000 Nand Flash ID: 0056780000000000 4. Project ID Not found You need working file to flash the phone. 5. Unknown Nor/Nand Flash Nor Flash ID: 0000000000000000 Nand Flash ID: 0056780000000000 Unknown Nand Flash This might be unsupported Flash Chip. Try Export Mood first. I think No More Confusion after this. BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
05-22-2013, 06:06 | #9 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | Quote:
