Dragon Box Chinese Phone Tool |
10-24-2012, 15:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 41
Member: 389660 Status: Offline Thanks Meter: 60 | Plez gpgdragon fix this bug VCC Pin:16, GND Pin:24, Signal Pin:14, 15, 17, 18, 19, 21, 22, 23, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:18 RXD:22 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:Spreadtrum Boot Block version 2.0 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6600 All Done... READ INFO IS OK...... FORMAT THERE IS BUG.....CHECK THIS >> Getting Mobile Connection Info... VCC Pin:16, GND Pin:24, Signal Pin:14, 15, 17, 18, 19, 21, 22, 23, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:18 RXD:22 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:Spreadtrum Boot Block version 2.0 >>> Downloading First Boot... >>> Opening File Error,Please Check the File Path... File No Found:\DRAGON\GPGDragon new\system\spreadtrum\6600L_Write_Full_Flash_2.bin ALL THE OTHER WORKS FINE READ FLASH,WRITE FLASH. |
10-28-2012, 20:26 | #7 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1551401 Status: Offline Sonork: 58485 Thanks Meter: 0 | >> Getting Mobile Connection Info... VCC Pin:16, GND Pin:24, Signal Pin:14, 15, 17, 18, 19, 21, 22, 23, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:18 RXD:22 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:Spreadtrum Boot Block version 2.0 >>> Downloading First Boot... >>> Opening File Error,Please Check the File Path... File No Found:\DRAGON\GPGDragon new\system\spreadtrum\6600L_Write_Full_Flash_2.bin ALL THE OTHER WORKS FINE READ FLASH,WRITE FLASH plezzzzzzzz |
10-28-2012, 22:49 | #8 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
I can't Trust on your words.......! I checked All of Dragon V.3.xx (Also v2.11 to 2.3) setups but can't Find this file (6600l_Write_Full_Flash_2.bin) in it. I think they forgot to put this file in dragon setup Archive...Or its a bug of dragon software,which is locking for a file whom didnot exist. But if U Really Tested it and its work for u, then u have this file in the given directory (....\GPGDragon_V3.11x\system\spreadtrum\6600L_Wri te_Full_Flash_2.bin) or u have a bugfree version which we don't have. Just upload This File Or bugfree version Here To help your fellows and they will definitely appreciate your this effort. | |
