Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Thanks: 73
| problem write flash to 6600l2 Dear GpgDragon team i have 2 phones working( same brand and typical) , one wiz arabic, i want write the flash of that set to the other but i face the problem when writing flash: error flashing i choose the flash siz from expert mode 8m: here reading log: Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM130 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Reading Flash... Saved file to: C:\Documents and Settings\acer\Desktop\HGHGHGH All Done. Reading Project Version... Platform Version: MOCOR_09A_3216.W10.40_P1_Release Project Version: 7707_WANDE_1040_FL_FM_SC_H13_V02_110407_QQVGA_ENG_ POR_SPA_FRE MMI Version: SC6600L_sp6601l BASE Version: BASE_W09.20_P38.3 HW Version: SC6600L_sp6601l Project Bulid Time: 4-7-2011 14:56:4 but when write the arabic flash here the error: Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM130 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Erase Flash what is the wrong ????? |
| | #3 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: (United States Of Islam) Age: 26
Member: 399832 Status: Offline Sonork: 100.1584728 Thanks: 1,772
| read here :Dragon Exports Can we slov this problem |
| | #4 (permalink) | |
| Quote:
i can read the flash file from the mobile need the arabic, but i couldn't write the arabic flash, any trick in expert mode????? or i have to wait for update | |
| | #5 (permalink) | |
| Banned ![]() ![]() ![]() ![]() Join Date: Jun 2011 Location: Kerala,INDIA
Member: 1588766 Status: Offline Sonork: 100.1603756 Thanks: 75
| Quote:
check with different boot.....6600l-com post result | |
| | #7 (permalink) |
| here phonr info wiz ver 1.12 it may help u: Analysis the file... It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM130 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: 66007001 Flash: NOR_UNKNOWN Set FLASH Parameters... Settings have been completed! CPU: 66007001 Flash: User-defined Reading FileSystem info... File System Ver: 0A IMEI 1=359138101396023 (CRC Error) IMEI 2=359670101396034 (CRC Error) Failed to get address of NV. Read FS info...done |
| | #8 (permalink) | |
| Quote:
can you tell me the model name ? you make backup before flashing , ? if yes then plz once format the flash chip with manul method then again flash the set from backup flash files if you face any problem then plz contact me on sonork | |
| | #9 (permalink) |
| hi again, all my above tries i set the flash siz to 8m , but when i choose to set it to 16m here is info: Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM130 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Manufacturer: ST & NUMONYX, Device: Unknow CPU: SC6600L2 Flash: NOR_UNKNOWN setting the Flash Parameters... Settings have been completed! CPU: SC6600L2 Flash: User-defined Reading FileSystem info... File System Ver: 0A IMEI 1=359138101396023 (CRC Error) IMEI 2=359670101396034 (CRC Error) --------NOR_FLASH_CONFIG-------- Flash Bank count=0 EFS sector count=32768 File sector count=557056 Sector size=0x000C0000 Flash start addr=0x10000000 Flash size=0x01000000 Fix NV addr=0x02008B00 Product information addr=0x002C8B00 MMI resource addr=0x00182000 ------Auto Format Address------- Start=0x00200000 Size =0x000C8B00 Read FS info...done i will try to flash it then i will post thx |
| | #10 (permalink) |
| Thanks GpgDragon team today i learned that when using expert mode FIRST read info wiz different flash sizes 8m or 16 m BIG THANKS |
| | #13 (permalink) |
| OMG , u know i couldn't write that flash AGAIN ![]() i double check it, and guess what, the flash size is 4M ![]() i check it wiz another tool and when i set it to 4m wiz dragon it say error erase flash agian |
| | #14 (permalink) | |
| Quote:
set the file 16 MB and try again to flash the set but once again format the set manually before flashing | |
| | #15 (permalink) |
| hi faheem i did it wiz another tool here the log: Initialize boot... CPU Info 6600L/WT6228 Flash Type NOR Flash ID 00208828 Flash Model ST M58WR032QU Flash Size 0x400000(4.0M) Start Writing... Write Done! i hope dragon will support it Thanks again Last edited by sudsud; 06-07-2011 at 10:35. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | Yesterday 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
