Dragon Box Chinese Phone Tool |
10-13-2015, 14:42 | #6 (permalink) | |
Freak Poster Join Date: Sep 2008
Member: 869968 Status: Offline Thanks Meter: 43 | Quote: hello MR Dnt fool with forum user to kill thier Phones 1st test ur file then uplod this worng file dont download it when u download this file it name --->HSL-STYLE -A400-07 which is not compatable with Q_A400 Mobile,,,,,,,,,,,,, | |
The Following User Says Thank You to GSM MEHR For This Useful Post: |
03-03-2016, 09:45 | #8 (permalink) |
No Life Poster Join Date: May 2009 Location: pakistan
Member: 1028120 Status: Offline Sonork: 100.1607216 Thanks Meter: 90 | use this tested file https://mega.nz/#!h9kgDKSR!WhxorZ1du...F7eGUZC2BOY6R4 |
12-29-2016, 14:02 | #10 (permalink) |
Insane Poster Join Date: Dec 2007 Location: NIGERIA
Member: 645502 Status: Offline Sonork: 645502 Thanks Meter: 13 | Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM11 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... |
12-29-2016, 14:02 | #11 (permalink) |
Member: 645502 Status: Offline Sonork: 645502 Thanks Meter: 13 | Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM11 Driver Name->>>SPRD U2S Diag >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:0000ADBC Flash Size:20000000->512M Flash Name:NAND_HYNIXH8BCS0UN0MCR CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Fail. Format_Cache...Fail. Format_Misc...Fail. Format_UserData...Success. All Done... pls i need d above file |
