Dragon Box Chinese Phone Tool |
12-20-2012, 05:53 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Qmobile E5 don by usb VCC Pin:4, GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM35 Mobile Connection Success... Hardware Version:CA01 Software Version:0001 CPU_ID:00000000 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00400000 -> 4M Flash ID:0x00EF004000160000 Flash Name:SF_W25Q32BV ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x00000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 >>> Reading Flash... Reading Flash Done... >>> Getting Mobile Connection Info... VCC Pin:4, GND Pin:5, Signal Pin:1, 2, 3, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM35 Mobile Connection Success... Hardware Version:CA01 Software Version:0001 CPU_ID:00000000 >>> Downloading First Boot... Verifying First Boot... >>> Downloading Second Boot... >>> Authenticating BOOT... BOOT Validation Success... ================NOR Flash Info================= Flash Size:0x00400000 -> 4M Flash ID:0x00EF004000160000 Flash Name:SF_W25Q32BV ================NAND Flash Info================= Flash Size:0x00000000 -> 0M Flash ID:0x00000000 Flash Name:UNKNOWNUNKNOWN >>> Switching Baud Rate... Baud Rate is Switched To:921600 Formatting Start Adress(Hex): 0x003B5000 Size(Hex): 0x0004B000 >>> Formatting... All Done... |
04-22-2013, 06:16 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | its mtk chip so you can use mtk drivers for that |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
