Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Dragon Box Chinese Phone Tool |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: inside my SOFTWARE ROOM
Member: 761864 Status: Offline Thanks: 32
| r3850 pattern lock, pls help using spreadtrum 6800h tool logs; >>> Scan Mobile Pinout... USB Pinout: D+:19 D-:17 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX All Done... and it readed the codes as 1234 how can i fix this pattern lock? pls help..... THANKS |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009 Location: laguna
Member: 992568 Status: Offline Sonork: kulit Thanks: 30
| you cannot fix sir it because the new louche of this team is only for testing hope it will fix soon as possible reading and info are cannot help for now |
| | #5 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2008 Location: Algeria Age: 30
Member: 918393 Status: Offline Sonork: 100.1623533 Thanks: 5
| Working Solution It's Very Easy Because you Have Mirror Methode Too Pattern Lock In Chainesse Phone = Digit Lock Just Read Code From Flash File , Then Enter It As Digit You Don't See Digit On Screen But After That You Phone Will Be Unlocked Tested By Me On Same Phone As Your's 100/100 Worked |
| | #6 (permalink) | |
| Quote:
thanks... | |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: (United States Of Islam) Age: 26
Member: 399832 Status: Offline Sonork: 100.1584728 Thanks: 1,771
| try with latest ver :GPGDragon SPD 6800H Tool Ver 1.20 release (2012-6-12) |
| | #9 (permalink) | |
| Quote:
i used that version v1.20 but still pattern lock not apprear, any other solution sir? same as v1.0.. ![]() here is the v1.20 logs.. USB Pinout: D+:6 D-:8 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX >>> Reading Flash... Access To The Flash Mode2... Read Flash Done... >>> Analzing Code...Please Wait... IMEI 1: 359642049256957 IMEI 2: 359642049256965 IMEI 3: 358570010103893 IMEI 4: 910575601400468 Password1: 1234 All Done... pls. help. thanks... | |
| | #10 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2008 Location: Kathmandu, Nepal
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks: 135
| You can try with 6800h new version 1.5 GPGDragon Big Update For SPD 6800H Ver 1.5 release Or If not you have two option:- a) Use search button for hard reset or b) Flash the falty phone with Working file (from working Phone). BR Last edited by Dipendra Pathak; 06-18-2012 at 07:15. |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 516878 Status: Offline Thanks: 50
| need flash z3850 .........after fash itt firm backup phone dead help pls > Scan Mobile Pinout... VCC Pin:7, GND Pin:2, Signal Pin:1, 3, 4, 5, 6, 8, 9, 10, USB Pinout: D+:6 D-:8 >>> SCAN SCI Port... Detected SCI Port :COM73 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000AD76 Flash Size:04000000->64M Flash Name:HY27XS08121M Flash Factory:NAND_HYNIX >>> Wrtieing Flash ... Write NV To Flash ... Write BOOT_LOADER To Flash... Write MMIRES To Flash... All Done... |
| | #12 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jun 2008
Member: 786285 Status: Offline Sonork: sadikahmad@ymail.com Thanks: 21
| r3850 pattern lock, pls help using spreadtrum 6800h tool logs; >>> Scan Mobile Pinout... USB Pinout: D+:19 D-:17 Detected Mobile PinOut ... >>> SCAN SCI Port... Detected SCI Port :COM127 Mobile Connect Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:0X08000000->128M Flash Name:H8BCS0PG0MBP Flash Factory:NAND_HYNIX All Done... and it readed the codes as 1234 how can i fix this pattern lock? pls help..... THANKS Sir pls argent upload this flash fiile |
| | #13 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2010 Location: Bangladesh Age: 28
Member: 1390802 Status: Offline Sonork: 100.1602594 Thanks: 208
| Quote:
,,,,,,,,,,,,,, contact me too ,,,, | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:04 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 11 | 06-26-1999 06:22 |
