Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Dragon Box
Dragon Box Chinese Phone Tool
Old 08-16-2012, 07:28   #16 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
some bugs found in new updates plz dragon team remove these bugs from new update
Old 08-16-2012, 09:03   #17 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
Originally Posted by Dipendra Pathak View Post
Try latest version and post the screenshot of Dragon Connectiong Windows.
GPGDraogn V3.05 [ Full Support MTK 6255 ] More info inside the thread !!!
Good Luck Brother!!!
Dipendra Pathak
Uploaded with ImageShack.us
The Following User Says Thank You to Rin2 For This Useful Post:
Old 08-16-2012, 09:12   #18 (permalink)
amc_khan's Avatar
Member: 638447
Sonork: 100.1609504
chang baud rate 115200 i try it 100% your problem solve post result
Old 08-16-2012, 09:13   #19 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
Ok with another handset..
Old 08-16-2012, 09:14   #20 (permalink)
Rin2's Avatar
Member: 982335
Sonork: 100.1603225
I tried.
Dont work for me !
Old 08-17-2012, 02:19   #21 (permalink)
Member: 580233
Dipendra Pathak
Update my thread if the same error happen, i hope that this new version again woulc fix my problem...
Thanks for aswering all my question...
good work GPG team..
Old 08-17-2012, 12:12   #22 (permalink)
Member: 772242
Sonork: Kene
Originally Posted by Faheem Anjum View Post
what is the status of phone ?
I think the new gpg update is riddled with a lot of bugs. It cant connect to coolsand cpu .. always showing return data error. Even the factory setting function that is added to mtk isn't working. I tried it with several phones, the operation was successful but the phones still maintains its security code and nothing changes. The new update works fine with mstar thats all.
Old 08-17-2012, 18:20   #23 (permalink)
serseg.gsm's Avatar
Member: 77394
similar error here but with "Spreadtrum".
phone condition: water adamaged but cleaned and not power on.
>>> Getting Mobile Connection Info...
    VCC Pin:10,
    GND Pin:1, 4,
    Signal Pin:2, 5, 6, 8, 9, 11,
>>> Scanning Mobile PinOut...
    USB Pin Out: D+:9  D-:8
>>> Scanning SCI Port...
    Detecting SCI Port :COM11
    Mobile Connection Success...
>>> Return DATA Error!!!
Old 08-17-2012, 21:41   #24 (permalink)
Member: 985126
Sonork: 100.1626690
I have the same error please gpgdragon team fix some bugs!!
Old 08-17-2012, 21:44   #25 (permalink)
Member: 985126
Sonork: 100.1626690
I have the same error please gpgdragon tema fix some bugs!!
Old 08-18-2012, 07:04   #26 (permalink)
Member: 75876
Originally Posted by bench betita View Post
what i want is,.. to clarify what is the best solution for that error,..by the way the unit is in good condition right now,. i release it to my custumer 2 days ago..
i wonder, why i have that error in new version?..
this is also happen to me in new version both 3.04 and 3.05 return data error
but on 2.13 it has no error.
Old 08-19-2012, 00:40   #27 (permalink)
Member: 161646
version 3.05
VCC Pin:
GND Pin:2,
Signal Pin:6, 7, 8, 9, 10,
Get Mobile PinOut: TXD:9 RXD:7
>>> Connecting Mobile...
Hardware Version:0001
Software Version:0980
CPU_ID:00000003
>>> Downloading First Boot...
Old 08-19-2012, 04:45   #28 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Return to Data has many meninges :
1. Unsupported mobile CPU Like :
skiing s9220 error while saving to u disk
2. Driver not properly install so mobile could not find driver properly.
3. Computer CPU not compatible with the program
4. Unsupported Operating System Using with the Program
5. Mobile not connected with the software. Sometimes, you need continue Holding POWER BUTTON until Operation is finished.
5.
Use lower Port if Possible (Below then 10)
6. Other unspecified Errors
a . Like Mobile is MTK and you select SPD so mobile Boot File not find and mobile could not boot.
b. Buggy windows (Operating System) is used
We suggest you, find the corrupt CPU and try to connect with it. if the Cpu type is SPD, and you try to connect with MTK, of course there will be DATA Error!!
Secondly
, Check the CPU type that Dragon supports or not. If not supports, there might be DATA ERROR!!
Thirdly, Install Driver Properly, if driver not install properly, software could not find boot file, so there might be Data Error!!
Fourthly
, Be sure that the Windows has no bug. And do not use unsupported Operating System that software could not recognize to the Operating system and there might be Data Error!!
Finally, Handle software properly. Check Sticky thread regularly. Search the post if you are not success to connect with the phone. And, if you not find the solution in the previous post, then post your problem as new thread with all the problem mentioned clearly with screen shots of Dragon connecting windows and wait for reply.
GOOD LUCK
DIPENDRA PATHAK
The Following 6 Users Say Thank You to Dipendra Pathak For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.35918 seconds with 11 queries
