Dragon Box Chinese Phone Tool |
11-04-2012, 17:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Trust unlocking
Member: 348518 Status: Offline Sonork: 100.1666935 Thanks Meter: 107 | Samsung S5830i china android spreadtrum help.. hang up in logo i need firmware tnx... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM31 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 CPU Name:6820/8810 All Done... i try to format but still hang up tnx... |
11-05-2012, 03:36 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Backup the firmware and try to flash it. Still not work, you have to flash with Working file from the Same phone. For flash file, please check our sub forum : Dragon Flash Files - GSM-Forum BR Dipendra Pathak |
06-10-2013, 12:09 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | solution found FIRMWARE FILE http://www.cubot.net/UploadFile/Soft...t_Software.rar FLASHING TOOL Zippyshare.com - DEBUG_TOOL.7z 3) Be sure to have installed the correct drivers. For my SC6820-device I see 5 items in Win7-32bit-device-manager (ADB-Composite, 2 x COM-ports, 2 x USB devices: all without exclamation marks). You can use the drivers from the package folder "SCI-android-usb-driver-jungo- v4-.rar". 4) Disable just in case your Win7 firewall. (If you are using Windows XP, you don't have to do this step) 5) Launch "ChannelServer.exe" from package folder "CHANNELSERVER" and allow firewall if asked. 6) Start "ResearchDownload.exe" from package folder "ResearchDownload". 7) In ResearchDownload-application chose firmware with first button (for me: 20121006_c909_JF_EAHC_V12.PAC).----- This is the STOCK ROM file that you have downloaded and Extracted it on STEP 1. 8) Be sure to SET the Baudrate-settings in ResearchDownload-Settings (second button). I recommend 115200. 9) Press the Start (Play) button in ResearchDownload-application (third button). 10) Turn off the phone. 11) Keep holding the "volume down"-key. 12) Without releasing the button "volume down" plug the usb-cord from phone to your PC (install the driver if not done before in step 2). 13) Keep holding down the Volume Down button..... The process of firmware-burning should start now in ResearchDownload-application and take approximately 1 Minute. 11. Wait until the firmware-flashing has been finished (A green sign appeares + "Passed" is written in ResearchDownload-application). 12. Remove the battery, wait 20 seconds. Put battery back and turn on the phone (first boot may take a while but not more than 5 minutes). Use this at your own risk. |
The Following User Says Thank You to kachman For This Useful Post: |
06-10-2013, 20:50 | #9 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | Quote:
need help here i got this set Android 4.0 Mobile Phone I9082 - China Android Mobile Phone,Android 4.0 | |
06-10-2013, 23:02 | #10 (permalink) | |
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
What is the Problem with your phone? | |
06-11-2013, 08:56 | #11 (permalink) | |
i read on forum and i think only pac file can solve my problem but where to find it!!! | |
09-10-2013, 05:20 | #13 (permalink) | |
Junior Member Join Date: Apr 2011 Location: Phillipine
Member: 1555770 Status: Offline Sonork: 1603764 Thanks Meter: 5 | Quote:
YES firmware is working one thing error touch screen problem how can fix | |
