Dragon Box Chinese Phone Tool |
06-13-2014, 16:17 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Brazil
Member: 1859706 Status: Offline Sonork: 100.1648492 Thanks Meter: 28 | Screen Lock on SPD 6531 not correct I'm trying to remove a screen lock from a SPD6531 phone, but code provided by Dragon is wrong, None of the password show match. |
07-23-2014, 16:41 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: algeria
Member: 228703 Status: Offline Thanks Meter: 21 | Quote:
GND Pin:20, Signal Pin:21, 22, 23, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:22 D-:23 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM19 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 Baud Rate is Switched To:921600 >>> Writing Flash File... Full Flashing .. Finish... >>> Analyzing Code...Please Wait... Screen Lock:4761 Password1: 1234 All Done... after format phne dead then write flash phone ok but always wrong scren lock wrong code | |
07-23-2014, 17:05 | #4 (permalink) |
Member: 228703 Status: Offline Thanks Meter: 21 | GPG Dragon_3.53new Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM19 Driver Name->>>SCI USB2Serial >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 >>> Mobile Info Flash ID:0x00C8006000000000 Flash Name:SF_GD25LQ128 Flash Size:0x01000000 -> 16M CPU Name:6531 All Done... >>> Analyzing Code...Please Wait... Screen Lock:4761 Password1: 1234 All Done...same problem help thx |
07-24-2014, 15:17 | #5 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | Quote:
07-25-2014, 09:12 | #8 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1924279 Status: Offline Thanks Meter: 14 | no way to dead your mobile because first readflash your mobile than format your mobile your mobile willbe unlocked successfully note: If the mobile is dead rewrite your flash file |
11-03-2014, 00:05 | #10 (permalink) |
Member: 237256 Status: Offline Thanks Meter: 91 | The code generated by dragon for this phone spd with chip 6531A is correct but the phoen must be flashed before the code will clear. This is typical of this type of spd phone with this particular chip 6531A. What to do is to use volcano and READ FLASH (do not disconnect phone from box) then write back the file to the phone (still do not disconect phone from box) then click on FORMAT and then click RUN. After format is successful then disconnect phone and check. Most phones with this chip will ask you to calibrate it and the code is cleared and phone now working fine. |
