Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Dragon Box
Dragon Box Chinese Phone Tool
Old 01-29-2013, 12:33   #1 (permalink)
JONONItelecom™'s Avatar
Member: 1076772
Sonork: 100.1601881
SPD 6800H Chip's Info. Writing Flash. Format Flashing Failed History Done
lSPD 6800H Flashing History
Here the picture
Connection Info...
>>> Reading Flash...
>>> Return DATA Error!!!
>>> Auto Formatting ...
Flash File Select
>>> Writing Flash File...
Terminated...
Writing NV To Flash ...
Writing BOOT_LOADER To Flash...
Writing KERNEL_IMG To Flash...
Writing USER_IMG To Flash...
Write MMIRES To Flash...
All Done...
>>> Getting Mobile Connection Info...
VCC Pin:
GND Pin:10,
Signal Pin:1, 2, 3, 4, 5, 6, 9,
>>> Scanning Mobile PinOut...
>>> USB Pinfind No need Hold Mobile Power key...
USB Pin Out: D+:6 D-:4
>>> Scanning Mobile USB Port...
Detecting Mobile USB Port :COM47
Mobile Connection Success...
>>> Downloading First "boot1.bin" Success...
Reading the First Boots:
Spreadtrum Boot Block version 1.1
>>> Downloading Second "boot2.bin" Success...
>>> Mobile Info
CPU Name:6800H
Flash ID:0000ADA1
Flash Size:08000000->128M
Flash Name:H8BCS0PG0MBP
Factory Flash:NAND_HYNIX
All Done...
VCC Pin:
GND Pin:10,
Signal Pin:1, 2, 3, 4, 5, 6, 7, 9,
>>> Mobile Info
CPU Name:6800H
Flash ID:0000ADA1
>>> Reading Flash...
Accessing To The Flash Mode2...
VCC Pin:
GND Pin:10,
>>> Please Hold the Power key...
Get Mobile PinOut: TXD:1 RXD:5
Mobile Firmware Version:SPRD3
>>> Downloading First Boot...
>>> Mobile Info
Project ID :Spreadtrum Boot Block version 1.1
>>> Downloading Second Boot...
Baud Rate is Switched To:921600
>>> Mobile Info
CPU Name:6800H
Flash ID:0000ADA1
Flash Name:NAND_HYNIXH8BCS0PG0MBP
>>> Auto Formatting ...
Format_FS...Success.
Format_HFS...Success.
All Done...
VCC Pin:3,
GND Pin:10,
Signal Pin:1, 2, 4, 5, 6, 7, 9,
>>> Mobile Info
>>> Mobile Info
CPU Name:6800H
Flash ID:0000ADA1
>>> -Analyzing Flash File...
Get Flash Format: User Read Full Flash...
Flash Size:0X04200000->66M
Detecting Flash File Format : Full Flash File...
Document processing success...
c:\temp.bin
>>> Decompressing file...
NV_ADD :0x01348000 SIZE: 0x00010000
BOOT_ADD :0x00008000 SIZE: 0x00018000
KERNEL_ADD :0x00060000 SIZE: 0x00201A90
USER_ADD :0x002E0000 SIZE: 0x00F96610
MMIRES_ADD :0x01388000 SIZE: 0x01085550
UDISK_IMG_ADD:0x037E8400 SIZE: 0x00008000
PRELOAD_ADD :0x037F0400 SIZE: 0x006C4A50
Waiting For Your Confirmation...
Write_NV...
Write_BOOT...
Write_KERNEL...
Write_USER...
Write_MMIRES...
Write_UDISK_IMG...
Write_PRELOAD...
Terminated...
VCC Pin:
GND Pin:10,
>>> Mobile Info
CPU Name:6800H
Flash ID:0000ADA1
Software Auto adjust "MMIRES" Size : 0x0107D150
All Done...
The Following 4 Users Say Thank You to JONONItelecom™ For This Useful Post:
Page generated in 0.28204 seconds with 10 queries
