Member: 1368568
Thanks Meter: 2 | spd6803H error in flashing Hello!
I have problems at record full read out from the same phone. I tried to write down both on USB and on COM interface, at different speeds from 115200 to 921600 and different boots. Help me, please!
6800H_Write_Boot_1
> Quote:
>> Getting Mobile Connection Info...
VCC Pin:21, 22,
GND Pin:1, 2, 15, 16, 20,
Signal Pin:4, 6, 7, 8, 18, 19,
>>> Scanning Mobile PinOut...
>>> USB Pinfind No need Hold Mobile Power key...
USB Pin Out: D+:4 D-:6
>>> Scanning Mobile USB Port...
>>> Detecting COM PortCOM133
>>> Connecting Mobile...
Mobile Connection Success...
Mobile Firmware Version:SPRD3
>>> Downloading First Boot...
>>> Mobile Info
Project ID :Spreadtrum Boot Block version 1.1
>>> Downloading Second Boot...
Baud Rate is Switched To:921600
>>> Mobile Info
CPU Name:6803H
Flash ID:0000ECA1
Flash Size:08000000->128M
Flash Name:NAND_SamSungK9K1G08X0A
>>> -Analyzing Flash File...
Get Flash Format: User Read Full Flash...
Flash Size:0X08400000->132M
Detecting Flash File Format : Full Flash File...
Document processing success...
c:\temp.bin
>>> Decompressing file...
NV_ADD :0x01A40000 SIZE: 0x00010000
BOOT_ADD :0x00008000 SIZE: 0x00018000
KERNEL_ADD :0x00020000 SIZE: 0x00206E90
USER_ADD :0x00340000 SIZE: 0x014803D0
MMIRES_ADD :0x01A80000 SIZE: 0x020DF0B0
UDISK_IMG_ADD:0x04280A00 SIZE: 0x00020000
PRELOAD_ADD :0x042A0A00 SIZE: 0x00374E40
Waiting For Your Confirmation...
>>> Writing Flash File...
Write_NV...
Write_BOOT...
Write_KERNEL...
Write_USER...
| 6800H_6803_Write_Boot_2 Quote:
VCC Pin:21, 22,
>>> Mobile Info
>>> Mobile Info
CPU Name:6800H/6803
c:\temp.bin
Write_NV...
Write_BOOT...
Write_KERNEL...
Write_USER...
Write_MMIRES...
Write_UDISK_IMG...
Error CODE:84--> CMD_EERPR --> UNKNOWN
>>> Return DATA Error!!!
| 6800H_6803_Write_Boot_3 Quote:
VCC Pin:21, 22,
>>> Mobile Info
>>> Mobile Info
CPU Name:6800H/6803
c:\temp.bin
Write_NV...
Write_BOOT...
