Dragon Box Chinese Phone Tool |
05-30-2013, 14:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | startel s600 not understand pls reply..(Solved) log : >> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:2, 4, 24, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:24 RXD:2 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Error:Get Mobile Version Time...Please Select Others Boot and Try again... i try all boot loader but same. and always select com not work usb mode. pls reply. thanks mahir |
05-30-2013, 14:29 | #2 (permalink) |
Member: 1128573 Status: Offline Thanks Meter: 242 | CPU IS SPD 6530A. format log = >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:2, 4, 24, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:24 RXD:2 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6530 Flash ID:0x2CCB170000000000 Flash Name:SF_N25W64 Flash Size:0x00800000 -> 8M Baud Rate is Switched To:115200 >>> Auto Formatting ... Format Success.. |
The Following User Says Thank You to mahir ashab For This Useful Post: |
07-21-2013, 06:59 | #3 (permalink) | |
Freak Poster Join Date: May 2008
Member: 774718 Status: Offline Thanks Meter: 47 | Quote:
07-22-2013, 11:12 | #4 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | for flash file please post your request in the dragon sub-forum bro : Dragon Flash Files - GSM-Forum BR Dipendra Pathak |
11-28-2013, 14:25 | #6 (permalink) |
Junior Member Join Date: Oct 2011 Location: Dhaka
Member: 1670718 Status: Offline Sonork: 100.1608520 Thanks Meter: 3 | startel s600 CPU Name:6530 Flash ID:0x2CCB170000000000 Flash Name:SF_N25W64 Flash Size:0x00800000 -> 8M ASDF - Download - 4shared - Alamin Khan |
11-28-2013, 17:11 | #7 (permalink) |
Major Poster Join Date: Mar 2012
Member: 1737595 Status: Offline Sonork: [email protected] Thanks Meter: 15 | star tel s600 write flash problem >>> Getting Mobile Connection Info... VCC Pin: GND Pin: Signal Pin:5, 6, >>> Scanning Mobile PinOut... >>> Please Hold the Power key... Get Mobile PinOut: TXD:6 RXD:5 >>> Please Hold the Power key... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.2 CPU Name:6530 Flash ID:0x2CCB170000000000 Flash Name:SF_N25W64 Flash Size:0x00800000 -> 8M Baud Rate is Switched To:115200 >>> Writing Flash File... Full Flashing .. Error CODE:FF--> CMD_EERPR --> UNKNOWN Please solution give me. |
12-02-2013, 12:32 | #8 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Chittagong, Bangladesh
Member: 1706809 Status: Offline Thanks Meter: 63 | Set baudrate ''115200'' then flash. it will be ok 10000000000000000% test by me. |
The Following User Says Thank You to shohidsd1 For This Useful Post: |
