Dragon Box Chinese Phone Tool |
01-19-2012, 15:10 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: BIRBHUM,W.B,INDIA
Member: 1707667 Status: Offline Sonork: 100.1611124 Thanks Meter: 60 | Try to recover dead set :not succeed TODAY I GOT A NEW BASSOON F10 AND DID THE FOLLOWING THINGS WITH DRAGON V2.11 BUT NOT POWER ON. FIRST I READ NEW PHONE IN NORMAL MODE HARE IS LOG Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=D:\bassoonf10(normal) Comport=COM13 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000C25A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: D:\bassoonf10(normal) All Done. Reading Project Version... Error: Unsupport FileSystem. THEN WRITE THE FILE TO DEAD PHONE LOG Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Enable Range[start]=0x0 Range[size]=0x00400000 Interface=COM FlashFile=D:\bassoonf10(normal) Comport=COM13 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=User-defined NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000125A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! CPU: SC6610/20 Flash: User-defined Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. NOT POWER ON THEN I READ THE NEW PHONE EXPERT MODE (4MB SETTING) Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Enable Range[start]=0x0 Range[size]=0x0 Interface=COM FlashFile=D:\bassoonf10expert Comport=COM13 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=User-defined NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000C25A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! CPU: SC6610/20 Flash: User-defined Reading Flash... Saved file to: D:\bassoonf10expert All Done. Reading Project Version... Error: Unsupport FileSystem. then write the file to the dead phone log Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6600L/WT6226-USB Expert Mode=Enable Range[start]=0x0 Range[size]=0x00400000 Interface=COM FlashFile=D:\bassoonf10expert Comport=COM13 Baudrate=921600 CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=SF_GD25Q32 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= CPU_Type=SC6610/20 CPU_ID=66100000 NOR_ID=00C8004000160000 NOR_Size=4MB NOR_Name=User-defined NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000125A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! CPU: SC6610/20 Flash: User-defined Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. phone still dead two file uploaded |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
