Dragon Box Chinese Phone Tool |
07-14-2014, 13:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Walron primo D2 format fail - >>> Return DATA Error!!! >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM30 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6572 Hardware Version:8A00 Software Version:CA01 >>> Downloading First Boot... >>> Return DATA Error!!! How to solved the problem??? |
07-15-2014, 12:45 | #6 (permalink) |
Member: 1369772 Status: Offline Thanks Meter: 297 | here is screenshoot |
07-15-2014, 15:36 | #8 (permalink) |
Member: 1369772 Status: Offline Thanks Meter: 297 | |
07-15-2014, 16:16 | #11 (permalink) |
Member: 1369772 Status: Offline Thanks Meter: 297 | Untick scan port although return data error |
07-16-2014, 05:33 | #12 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Now, try to use 1. JIG + vcc and gnd cable (Do not use USB Cable and Battery) 2. Tick "Scan Pinout" 3. choose USB (Not COM) Good Luck BR Dipendra Pathak |
07-17-2014, 05:38 | #13 (permalink) | |
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
I already use your process.... >>> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:0E_8D PID:00_03 This is a MTK chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM30 Driver Name->>>MTK USB Port Mobile Connection Success... CPU_ID:MT6572 Hardware Version:8A00 Software Version:CA01 >>> Downloading First Boot... >>> Return DATA Error!!! Can you post pin out image (RX/TX) | |
