Dragon Box Chinese Phone Tool |
03-17-2012, 19:22 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | why phone powered on after pinouts detected? i have a chines nokia E7 MTK, when i try to read its info i got this Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=17 TXD=19 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. ----------------- here phone powered on and box continue and gives this error . Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 please help. |
03-17-2012, 20:12 | #2 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: DUBAI/UAE
Member: 430770 Status: Offline Sonork: 100.1611576 Thanks Meter: 238 | Quote:
Try to change boot version .. | |
03-18-2012, 06:59 | #7 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | @KhalIman plz check fst which flash chip inside the phone one more thing when you come on this stage then disconnect VCC and connect it again whole disconnecting and connecting again Vcc keep the power button pressed do it and let me know |
03-18-2012, 07:28 | #8 (permalink) | |
Freak Poster Join Date: Feb 2008
Member: 699543 Status: Offline Thanks Meter: 7 | Quote:
try but same problem also with me here is info only security code set is on ((( Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 Connection Failed. thhnx if u can help................. | |
03-18-2012, 07:49 | #9 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: <INDIA> % <CHINA>
Member: 1359320 Status: Offline Sonork: 100.1620477 Thanks Meter: 79 | Quote:
if its mtk 6253 ic then when its detect pinout just release the power key and again press it 100% it will connect | |
03-18-2012, 07:54 | #10 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Pakistan & Bahrain Age: 37
Member: 617073 Status: Offline Sonork: 100.1611349 Thanks Meter: 316 | Quote:
03-18-2012, 08:35 | #13 (permalink) | |
Member: 699543 Status: Offline Thanks Meter: 7 | thnx........................ Quote:
thnx i also try if u have team viewer u can also check................ | |
03-18-2012, 10:32 | #15 (permalink) | |||
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Quote:
the the flash chip is mtk, as freeware detected it. i tried disconnecting vcc and connecting again but same problem. Quote:
thank you all again for your help, wish we can solve this problem. | |||
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
