Dragon Box Chinese Phone Tool |
12-19-2013, 13:17 | #18 (permalink) |
Freak Poster Join Date: Mar 2012 Location: BARNALA
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | @dipendra pathak bro as you wrote..6. If your devics has broken point in of VCC from the Socket (Charging, Earphone or USB Socket), you can also repair your device because this cable has given extra VCC from the wire, not only Vcc but also BSI and GND. I think, users can understand this. if i have set in such case which you described...thn have i to oped set to make vcc point to groung or i can repair it without opening set with any other wa ??????? pls rply ASAP |
12-19-2013, 13:32 | #19 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
Yes, you are right, You can make it USB Daga Cable only if you do not connect VCC, BSI and GND. But, to use as USB you have to switch ON the button so that Data Cable VCC also ON for USB device. You can also use it as Nokia Flashing to bring device into Local Mode. For, This you can use VCC, BSI and GND for battery pins. If you don't need VCC, BSI and GND and wants to flash from Battery just disconnect VCC, BSI and GND extra cable. And, as you told, You can solder from different point where you found VCC or GND or BSI point from the extra VCC, BSI and GND cable. Finally, Some device in android no need Vcc to repair IMEI so that we Switch Off its VCC line from switch. Remaining thing you can use either battery or VCC, BSI and GND according to the work. Thank you for understanding us. BR Dipendra Pathak | |
12-19-2013, 14:42 | #20 (permalink) |
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | 1.u mean i can use this cable to flash any nokia handset ..no need any flashinf (rj45) cable and its pinouts??? 2. if i use usb cable +vcc,bsi,gnd pins in nokia handset...set came into download mode.....can i use it as fbus cable?? or i have to use method ad usb flashing or i can use both (fbus+usb ? 3.can i use this cable to read/write/imei repair any chines andriod handset having MTK,SPD or QUALCOMM ic in it last que 4. i need this cable urgent ..i m from punjab....from where can i get it |
12-19-2013, 14:47 | #21 (permalink) |
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | as u told ..Finally, Some device in android no need Vcc to repair IMEI so that we Switch Off its VCC line from switch. u mean..which android device not need vcc power ,if we short vcc pin to ground then this set will take boot ...and we can easily do read/write/imei repair ??? m i ryt |
12-20-2013, 04:38 | #22 (permalink) | |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Quote:
Even Blind man can Answer this. When you use Power from Battery, then, you need VCC from Cable? Again, When you use VCC from battery point then you need again vcc from USB Cable? He says this is USB cable, so can you flash from f-bus? of course not. Diosa | |
12-22-2013, 20:02 | #23 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Mobile plus
Member: 844892 Status: Offline Sonork: 100.1618521 Thanks Meter: 151 | 1. You can bring the Nokia LOCAL MODE so that you can flash the nokia device from USB method because this cable is inbuilt resistance to bring the device to the Local Mode. number 1 option I am not clear this cable how to local mood Nokia? pls explain |
01-09-2014, 08:03 | #29 (permalink) | |
BR Dipendra Pathak Last edited by Dipendra Pathak; 01-09-2014 at 08:58. | |
