Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Dragon Box
Dragon Box Chinese Phone Tool
Old 01-04-2013, 12:53   #1 (permalink)
bsat's Avatar
Member: 195225
mt625a write imei problem
mt625a
>>> Getting Mobile Connection Info...
VCC Pin:15,
GND Pin:21, 23, 24,
Signal Pin:13, 14, 16, 17, 18, 19, 20, 22,
>>> Scanning Mobile PinOut...
>>> Please Hold the Power key...
Get Mobile PinOut: TXD:18 RXD:19
>>> Connecting Mobile...
Hardware Version:CA01
Software Version:0001
CPU_ID:00000000
>>> Downloading First Boot...
Verifying First Boot...
>>> Downloading Second Boot...
>>> Authenticating BOOT...
BOOT Validation Success...
================NOR Flash Info=================
Flash Size:0x00300000 -> 3M
Flash ID:0x00EF004000160000
Flash Name:SF_W25Q32BV
================NAND Flash Info=================
Flash Size:0x00000000 -> 0M
Flash ID:0x00000000
Flash Name:UNKNOWNUNKNOWN
All Done...
Old 01-04-2013, 12:55   #2 (permalink)
bsat's Avatar
Member: 195225
VCC Pin:
GND Pin:21, 23, 24,
"IMEI "options color to yellow then you can ReWrite IMEI...
case write imei not open
Old 01-04-2013, 14:13   #3 (permalink)
Member: 751662
VCC Pin:
GND Pin:21, 23, 24,
Try version 2.13, AT mode.
New wersion is often can`t write IMEI.
The Following User Says Thank You to mobilife_serv For This Useful Post:
Old 01-04-2013, 21:12   #4 (permalink)
bsat's Avatar
Member: 195225
same problem frienddd
Old 01-05-2013, 05:52   #5 (permalink)
Unlockinfo's Avatar
Member: 1785930
Sonork: 100.1622600
after formate write imei and reply me post...............
Old 01-05-2013, 08:40   #6 (permalink)
bsat's Avatar
Member: 195225
but how can write imei after format pls explain me
Old 01-05-2013, 11:18   #7 (permalink)
bsat's Avatar
Member: 195225
No solution for dragon box????????????
Old 01-05-2013, 13:47   #8 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
I Already Say Not Solved Your Problem Yet With Dragon Use Other Tool Like Volcano.
BR.
Arsalan gsm2000.
Old 01-05-2013, 19:59   #9 (permalink)
bsat's Avatar
Member: 195225
BR.
Arsalan gsm2000.
i use dragon box frien any user use 2 tool for chinese phone?
Old 01-07-2013, 08:20   #10 (permalink)
bsat's Avatar
Member: 195225
help me pls i accepte telfone ggood work juste not read sd carte
Old 01-07-2013, 08:21   #11 (permalink)
bsat's Avatar
Member: 195225
Old 01-07-2013, 08:41   #12 (permalink)
Member: 1048937
imei tool
try this imei tool use usb with battery phone must be switched on
WRITE IMEI DUIL.rar
Old 01-07-2013, 08:53   #13 (permalink)
bsat's Avatar
Member: 195225
Old 01-07-2013, 15:09   #14 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: 100.1621109
Bro try collect same working phone and read flash and write in faulty phone that is the last chance or try to collect same flash file and write thats all
Page generated in 2.66200 seconds with 10 queries
