xphone 1130 Failed to set Flash parameters...Solved Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast... RXD=3 TXD=4 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000206A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Failed to set Flash parameters... |
Same problem Initializing... DA_LIB_VER_3.6.8.5 It is sensing the pinout fast... RXD=3 TXD=4 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000206A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Failed to set Flash parameters... |
Hotfile.com: One click file hosting: DownloadAgentLib.rar DOWNLOAD THIS AND COPY TO YOUR DRAGON FOLDER AND TRY TO FLASH AGAIN |
Same problem ........... |
Initializing... DA_LIB_VER_3.6.8.5 It is sensing the pinout fast... RXD=14 TXD=16 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000026A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_FM25Q32 setting the Flash Parameters... Failed to set Flash parameters... what is salutaion for this error sir |
i have same problem for my box |
CPU: SC6610/20 Flash: SF_FM25Q32 new cpu not supported yet, Plz wait to Announce new Update. |
Change baudrate 921600 to 115200.. |
Initializing... DA_LIB_VER_3.6.8.5 It is sensing the pinout fast... RXD=14 TXD=16 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000026A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_FM25Q32 setting the Flash Parameters... Failed to set Flash parameters... when you select 6600L-COM boot,you must set the baudrate to 115200.. |
you must set the baudrate to 115200. |
prb sloved thanks gpg dragon |
formes700 find use avator box and bordrate change 115200 and 10000% te |
