Dragon Box Chinese Phone Tool |
10-27-2012, 10:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: india Age: 48
Member: 549926 Status: Offline Thanks Meter: 118 | yxtel c900 security code problem VCC Pin: GND Pin:20, Signal Pin:13, 21, 22, 23, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:22 D-:23 >>> Searching Mstar Driver... Mstar Driver Not Found!!! >>> Return DATA Error!!! which ic inside |
10-28-2012, 05:11 | #3 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
Check about, this is Driver problem. Install Mstar Driver and post the success report. Good Luck BR Dipendra Pathak | |
04-18-2013, 04:11 | #6 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1919441 Status: Offline Thanks Meter: 0 | Hi, I have been using this YXTEL C900, since few days. I had unknowingly unlocked & registered to face icon.. since, then when I try to go to menu.. its asking for password.... I wuld be highly obliged if you could suggest me on this, thanks. Regs, Raghav. [email protected] |
04-18-2013, 06:29 | #7 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
04-19-2013, 04:28 | #10 (permalink) |
Member: 1919441 Status: Offline Thanks Meter: 0 | YXTEL C900 -- some code problem Hi Bro, It was not working.. on switching on mobile I have this screen (above).. later I tried as per your steps.. usb which I had connected never let me go beyond... to the menu options.. below you can see the screen, Im not able to go beyond.. pls suggest, thanks. SAM_1793.JPG SAM_1794.JPG SAM_1795.JPG |
04-19-2013, 11:15 | #11 (permalink) | |
10-07-2013, 12:34 | #12 (permalink) |
Freak Poster Join Date: Jan 2013 Location: palani. tamilnadu
Member: 1862407 Status: Offline Sonork: india Thanks Meter: 37 | .............................. >> Getting Mobile Connection Info... VCC Pin: GND Pin:20, Signal Pin:13, 21, 22, 23, 24, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:22 D-:23 >>> Searching Mstar Driver... Mstar Driver Not Found!!! >>> Return DATA Error!!! Quote: Originally Posted by bluishrags View Post Hi, I have been using this YXTEL C900, since few days. I had unknowingly unlocked & registered to face icon.. since, then when I try to go to menu.. its asking for password.... I wuld be highly obliged if you could suggest me on this, thanks. Regs, Raghav. [email protected] Open a new theard my bro and always post screen shot for fast and better answer Report Post Reply With Quote which ic inside Report Post Reply With Quotedear bro.... c900 yxtel is mtk 625a chipset...volcano can run format, write imei don worry... and im done 2 mobiles .... if am right give thanks button. |
10-08-2013, 05:10 | #15 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | here is log Definition Applied Waiting for USB Port... Set USB Modem Driver (COM12) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6250DA(625A) Ver: CA01_S0001 Ver: CA01 md:8000 Downloading Boot7 ... Nor Flash Code: 00C20025(00380000) Nor/SF Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0x0+0x0 Reading(Nor)... The phone information: GAOPHONE50_COSMOS_11B_PCB01_GPRS_MT6250_S00.F620YX ER081303021510.BIN the file not be encrypted Read OK. Total time: 0 mins 59 s File Save to: C:\Documents and Settings\user\Desktop\Yxtel C900\GAOPHONE50_COSMOS_11B_PCB01_GPRS_MT6250_S00.F 620YXER081303021510.BIN |
