Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > Smart-gsm team
Old 03-12-2014, 00:22   #1 (permalink)
Member: 352414
Thanks Meter: 41
i problem ATF 4 IN 1
mr i problem ATF 4 IN 1 Ultimate JTAG/EMMC/ISP/MMC Adaptor is not workin error faild to reset micro sd card
Old 03-12-2014, 02:12   #2 (permalink)
dre2's Avatar
Member: 1190283
Thanks Meter: 67
Change original micro sd card and try again
Old 03-12-2014, 19:25   #3 (permalink)
Member: 352414
Thanks Meter: 41
i did change it no luck
Old 03-13-2014, 06:16   #4 (permalink)
Member: 1300483
Thanks Meter: 27
Hi,
Go to Connection Manager Tab and click on Read Card Info.
Old 03-13-2014, 06:37   #5 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
iif no luck Check the SDCard Slot ....
Old 03-15-2014, 14:02   #6 (permalink)
Member: 352414
Thanks Meter: 41
I try it so many times is not working error faild to reset micro sd card
Old 03-16-2014, 22:38   #7 (permalink)
Member: 1300483
Thanks Meter: 27
bro then your sd card slot not working get a rj45 sd card reader or try to hardware fix it
Old 03-17-2014, 15:36   #8 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
Which box you are using ?
ATF Chrome or ATF NITRO
Old 03-19-2014, 17:06   #9 (permalink)
Member: 82802
Thanks Meter: 11
i have same problem.
Tested with 2 GB, 8GB and 16 GB SD Card
i used ATF Nitro Box and ATF Software 11.10
Page generated in 0.16537 seconds with 8 queries
