AVATOR BOX (China Phones Service Tool) |
02-21-2013, 08:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2012
Member: 1789341 Status: Offline Sonork: 1627336 Thanks Meter: 14 | 6610-20 not running bootloader Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast... RXD=7 TXD=6 Connecting... .....just stop here....nothing happening....phone is locked,,,any solution |
02-21-2013, 08:57 | #2 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
Remove Positive ( +) pin from phone and conect it again to phone after 1 or 2 seconds ,Try and post result. Note. Plz. next time do not post same problem here and there in this section . Only one post for any question is enough. Regards amn32 | |
The Following User Says Thank You to amn32 For This Useful Post: |
02-21-2013, 09:18 | #3 (permalink) |
Member: 1789341 Status: Offline Sonork: 1627336 Thanks Meter: 14 | Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast... RXD=7 TXD=6 Connecting... Connected...sending boot... FDL test...OK SC66x0 Unsupport OmnipotentMode in this time. ArmBootMode: 6610000000346A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Support br115200 on SC6610/20 & SC6530 only. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\Administrator\Desktop\wing101 All Done. thanks....and i will be carefull in future..... one thing more...whats is omnipotent mode and expert mode??? |
The Following User Says Thank You to dineshgaba For This Useful Post: |
02-21-2013, 09:35 | #4 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | I,m trying to explain in easy words. 1.Omni potent ,mood is for some phones which can not be read easily by avator box.If we enable it ,this will try to work on phone in depth ,and Easy to understand this will enter in phone brain and we get good result. 2-Expert mood is for expert users who can work on Avator box manually ,Those users who knows better tio chooz file sizes ,for read and write. I hope you understand. Regards amn32 |
