AVATOR BOX (China Phones Service Tool) |
12-12-2014, 15:25 | #4 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
,click on authorised box ,enter password ,and ok button.Restart programe , | |
The Following User Says Thank You to amn32 For This Useful Post: |
12-13-2014, 04:10 | #5 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | thanks sir here is the log of avator box Checking box, wait... Box Firmware version: 1.58 Card Authorised Sucessfully. Box Authorised Sucessfully. Box Registered to gust but how to unlock pattern, with dongle it always failed, even i was enable usb debug.. here is the log by dongle.. Application: 1.0.0.16 Model: Autodetect Request information... Searching Phone... Timeout USB Debug should be Enabled ! please guide me |
12-13-2014, 05:12 | #6 (permalink) |
Member: 1763380 Status: Offline Thanks Meter: 86 | avator team please help me, i try with 2 phone, samsung s5830i with usb debug on and spc s1link, its spreadtrum cpu. on device manager driver is good but dongle cant find device. i want remove pattern both Application: 1.0.0.16 Model: Autodetect Request information... Searching Phone... Timeout USB Debug should be Enabled ! so guide me avator team, i,m new with avator box & dongle |
12-13-2014, 06:05 | #7 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
12-13-2014, 08:41 | #8 (permalink) | |
Member: 1763380 Status: Offline Thanks Meter: 86 | Quote:
i try with box, heres the log Initializing... DA_LIB_VER_6.1.0.5 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM20 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 00 Failed to get address of NV. Read FS info...done phone is too many pattern, and when i going to format just show conecting on log and nothing hapen | |
12-13-2014, 11:29 | #10 (permalink) |
Member: 1763380 Status: Offline Thanks Meter: 86 | Initializing... DA_LIB_VER_6.1.0.5 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 90 secret keys have been killed. All Done. finally pattern is gone sir, but now come with lock slide on touchscreen.. touchscreen working well, but it wont open the lock screen... |
12-13-2014, 12:22 | #11 (permalink) |
Member: 1763380 Status: Offline Thanks Meter: 86 | come with another phone, evercoss a5a* status is too many pattern.. here is the log Initializing... DA_LIB_VER_6.1.0.5 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM29 Connected...sending boot... Boot1 is Done. Wait for ACK... i try with boot 8810 and 6820 but no result.. is it bug mr lucky? also try using volcano & mcn but same failed... |
