AVATOR BOX (China Phones Service Tool) |
06-25-2014, 08:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | AVATOR Box&Dongle repair T9500 CPU SC8810 NAND_H8BCS0UN0MCR [test report] Read info: Code: -------------------Created: 24.06.2014 15:54:07------------------- Chip=SpreadTrum Action=ReadInfo FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM4 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_5.9.0.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 00 Failed to get address of NV. Read FS info...done +++++++++++++++++++End at: 24.06.2014 15:54:35+++++++++++++++++++ Code: -------------------Created: 24.06.2014 18:29:39------------------- Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=D:\ремонт\прога\Китайские телефоны\Spreadtrum\Spreadtrum_Android\T9500_ CPU 8810_Flash NAND_H8BCS0UN0MCR\T9500_CPU 8810_Flash NAND_H8BCS0UN0MCR.cmz Comport=COM4 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_5.9.0.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: D:\ремонт\прога\Китайские телефоны\Spreadtrum\Spreadtrum_Android\T9500_ CPU 8810_Flash NAND_H8BCS0UN0MCR\T9500_CPU 8810_Flash NAND_H8BCS0UN0MCR.cmz All Done. +++++++++++++++++++End at: 24.06.2014 19:20:29+++++++++++++++++++ Code: -------------------Created: 24.06.2014 11:57:48------------------- Chip=SpreadTrum Action=WriteFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x21002000 Interface=USB FlashFile=D:\ремонт\прога\Китайские телефоны\Spreadtrum\Spreadtrum_Android\T9500_ CPU 8810_Flash NAND_H8BCS0UN0MCR\T9500_CPU 8810_Flash NAND_H8BCS0UN0MCR.cmz Comport=COM4 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_5.9.0.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Erasing Flash... Done. Programming... All Done. +++++++++++++++++++End at: 24.06.2014 13:05:39+++++++++++++++++++ |
The Following User Says Thank You to Kolumb For This Useful Post: |
