AVATOR BOX (China Phones Service Tool) |
12-28-2010, 19:49 | #18 (permalink) |
Junior Member Join Date: Aug 2007
Member: 562782 Status: Offline Thanks Meter: 3 | i already select the proper com port base on the control panel profilic usb to serial. in my case com10. like i said before i don't have problem with the old version. that mean my com port is correct. the problem is when i'm trying to upgrade the box firmware.. it says Conjunction box error!!! |
12-28-2010, 23:55 | #19 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Quote:
The problem seems to be so simply solve.. You Need to reinstall your box driver and try to click on scan port in firmware update exe. after it will select your right comport and then you click update your problem will be solve.. Note: When you try to scan your comports you need to be sure your box will be alone connected with your pc. Best Of Luck! Br., GsmUniversal | |
The Following User Says Thank You to GsmUniversal For This Useful Post: |
12-29-2010, 08:54 | #20 (permalink) |
Member: 562782 Status: Offline Thanks Meter: 3 | still the same.. i try to uninstall the driver, download the setup file again from http://avatorbox.com/Avator_5.012.rar install the setup, install the driver, unplug other box, and run the flasher.exe. scan the port, then upgrade box.... but.. the problem wont go away.. i try to install on my laptop with windows 7 and the problem still the same.. Device manager Scan port Upgrade |
12-30-2010, 07:55 | #22 (permalink) |
Banned Join Date: Sep 2008 Location: in ur dreams
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | >>> Firmware file : 37376 Byte >>> Port open ok...... >>> Conjunction box...... >>> Conjunction box...ok...... >>> File: 146 page. >>> Write Box...... >>> Box UpGrade successful...... thanks |
12-30-2010, 09:25 | #23 (permalink) | |
Member: 562782 Status: Offline Thanks Meter: 3 | Quote:
anyone.. have same problem..?? how to solve this problem.. ?? is it box problem? if it is. i have to return it to distributor. | |
12-31-2010, 10:28 | #27 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 458 | Quote:
solve : 1-Avator 5.0.3 install 2-Avator_Ver_5.012 install 3-open Avator 5.0.3 install folder and Avator_Ver_5.012 install folder copy and paste Avator 5.0.3 install folder replace ok today tested 100/100 ok | |
The Following User Says Thank You to turkcellgsm For This Useful Post: |
12-31-2010, 19:57 | #30 (permalink) | |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | Quote:
this firmware upgrade similar to uct,gpgdragon,probably you need to upgrade to 1.50 then u'll able to upgrade to 1.51? cmiiw br, s1emens | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
