Avator Box new Update 26-12-10 installation guide [ Thread Closed ] All user of Avator box need to upgrade your box firmware to use this latest upgrade. Steps: * Download and run Setup latest Version 5.012 * After this in c driver go to C:\Avator Box\Avator-BOX_Firmware1.51\AB-BOX_Firmware1.51 * Run flasher exe * Press Scan Ports and then Select your box com port * Then press Upgrade-Box * After 45 to 60 second your box upgrade done and you able to see Box Upgrade Successful....... * Now You able to use latest version and also able to see box firmware 1.51 in software at connect time DOWNLOAD LINK For setup Ver.5.012 http://arunaexport.com/Avator.rar |
(Press Scan Ports and then Select your box com port) how to Scan Ports and then Select your box com port plz help me sir |
In software you able to see scan port press this button then all available port list come in this box and then select your box com port and then process. |
Thanks advance. |
i got problem when upgrade the firmware. it says Conjunction box error.. i already chose the right com port for the avator box. how to solve this problem.. thanks.. |
Dragon/uct/avator all box have same soft only gui changed upgradation soft is looks same |
i cant use this version bcoz this folder not created in in avatrar box folder Avator-BOX_Firmware1.51 |
Both Can you Explain Extractly What Error you Getting Any Screenshot Or Logs please Post Br., AvatorBox Team |
log here is the log >>> Firmware file : 37376 Byte >>> Port open ok...... >>> Conjunction box...... >>> Conjunction box error!!! |
