Avator Box SPD 6531 I9500 copy - Repair DONE [error other tool]
SPD 6531 I9500
[error other tool]
Info:
Format: Avator Box SPD 6531 I9500 copy - Repair DONE
Info:
CRC- Error
Read Backup: Quote: -------------------Created: 12.05.2014 15:36:33-------------------
Chip=SpreadTrum
Action=ReadFlash
FlashType=NOR
boot=6531
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=USB
FlashFile=D:\ремонт\прога\Китайские телефоны\MTK\MT6575\i9500
Comport=COM4
Baudrate=921600
CPU_Type=SC6531
CPU_ID=65310000
NOR_ID=00C8006000180000
NOR_Size=16MB
NOR_Name=SF_GD27Q128
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_5.9.0.0
Auto reset and search the USB-to-Serial...
Connecting...
Spd USB-to-Serial=COM16
Connected...sending boot...
FDL test...OK
ArmBootMode: 6531000000005A00_00
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 921600 is ok
Reading phone HW info...
Read info is done.
CPU: SC6531 Flash: SF_GD27Q128
setting the Flash Parameters...
Settings have been completed!
setting the Serial Flash Parameters...
Reading Flash...
Saved file to: D:\ремонт\прога\Китайские телефоны\MTK\MT6575\i9500
All Done.
+++++++++++++++++++End at: 12.05.2014 15:39:52+++++++++++++++++++ | Format:
Repair IMEI: Quote: -------------------Created: 12.05.2014 15:50:58-------------------
Chip=SpreadTrum
Action=IMEI
FlashType=NOR
boot=6531
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x0
Interface=USB
FlashFile=C:\Users\Cifroservis\Desktop\i9500
Comport=COM4
Baudrate=921600
Initializing...
DA_LIB_VER_5.9.0.0
Auto analyzing...
IMEI has been detected in rom-image. Group=2
Rebulid IMEI: [355273017386340] to [353056343960436] Create out file: C:\Users\Cifroservis\Desktop\Rebulid_IMEI_i9500
All Done.
+++++++++++++++++++End at: 12.05.2014 15:51:07+++++++++++++++++++ | Write repair file: Quote: -------------------Created: 12.05.2014 15:51:40-------------------
Chip=SpreadTrum
Action=WriteFlash
FlashType=NOR
boot=6531
Expert Mode=Disable
Range[start]=0x0
Range[size]=0x01000000
Interface=USB
FlashFile=C:\Users\Cifroservis\Desktop\Rebulid_IME I_i9500
Comport=COM4
Baudrate=921600
CPU_Type=SC6531
CPU_ID=65310000
NOR_Size=16MB
NOR_DieCnt=1
NAND_ID=
NAND_Size=
NAND_Name=
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
FDL test...OK
Done.
Done.
Read info is done.
Unlocking all blocks before program/erase...
Unlock Done.
Programming... Compare Image: Enable
All Done.
+++++++++++++++++++End at: 12.05.2014 15:54:22+++++++++++++++++++ | Result:
ALL done =)
