AVATOR BOX (China Phones Service Tool) |
11-25-2014, 17:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | AvatorBox copy iPhone 5G CPU 6531A [test report] Info: Code: Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_GD27Q128 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 80 IMEI 1=352273017386340 ------Auto Format Address------- Start=0x00F90000 Size =0x00070000 Read FS info...done Code: Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_GD27Q128 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 80 Start=0x00F90000, Size=0x00070000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. Code: -------------------Created: 25.11.2014 18:11:39------------------- Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6531 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Users\Cifroservis\Desktop\CPU_SC6531_Flash_SF_GD27Q128 Comport=COM4 Baudrate=921600 CPU_Type=SC6531 CPU_ID=65310000 NOR_ID=00C8006000180000 NOR_Size=16MB NOR_Name=SF_GD27Q128 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_GD27Q128 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Users\Cifroservis\Desktop\CPU_SC6531_Flash_SF_GD27Q128 All Done. +++++++++++++++++++End at: 25.11.2014 18:18:13+++++++++++++++++++ Code: Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_GD27Q128 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. Last edited by Kolumb; 11-26-2014 at 09:28. |
The Following 2 Users Say Thank You to Kolumb For This Useful Post: |
