AVATOR BOX (China Phones Service Tool) |
03-21-2015, 11:22 | #16 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Algeria is a North African Age: 35
Member: 1629321 Status: Offline Thanks Meter: 823 | DA_LIB_VER_6.2.0.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM28 Connecting... Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8820D00000000000_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading info... CPU: SC8825 Flash: EMMC_UNKNOW |
03-21-2015, 11:22 | #17 (permalink) |
Member: 1629321 Status: Offline Thanks Meter: 823 | Initializing... DA_LIB_VER_6.2.0.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM28 Connecting... Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8820D00000000000_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading info... CPU: SC8825 Flash: EMMC_UNKNOW |
03-21-2015, 11:51 | #18 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | Successfully reset the gmail ID without data lost of 8825 Screen shot attached: 1) 2) 3) |
The Following User Says Thank You to M.S.khan For This Useful Post: |
03-21-2015, 16:47 | #19 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
Br Puneet5154-AvatorBox HelpDesk | |
03-22-2015, 08:48 | #20 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Opal L4 pattern unlock done- Code: Initializing... DA_LIB_VER_6.2.0.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM25 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 129 secret keys have been killed. All Done. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
03-22-2015, 09:14 | #21 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | MMx A61 unlock done- Code: Initializing... DA_LIB_VER_6.2.0.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM12 Connecting... Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 7710DA0000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC7702 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 208 secret keys have been killed. All Done. |
The Following 3 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
03-23-2015, 12:14 | #22 (permalink) |
Freak Poster Join Date: Dec 2007 Location: sukabumi
Member: 649553 Status: Offline Thanks Meter: 45 | mtk 6260 read code Initializing... DA_LIB_VER_6.2.0.1 Tip: The phone must be able to power-on normally MTK USB Device found. Port=COM45 Connecting... Any errors please select another boot and try again. BB:6260, HardwareVer:8000, SoftwareVer:CA00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1463 |
03-27-2015, 20:33 | #23 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Colombia
Member: 448639 Status: Offline Thanks Meter: 165 | after the update my software not work Quote: Checking box, wait... Box Firmware version: 1.58 Box Authorised Failed Press " Box Manager " Tab i enter password reboot the soft but the same problem Box Authorised Failed help i tried more the ten times and not work not down licence file before the update the box working done i send one PM, 7 days not anwser from support |
03-28-2015, 07:30 | #24 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
May be your Internet firewall blocking the server access . | |
03-29-2015, 10:31 | #26 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Some boot protected models ,like some Alcatle androids are not supported . Better post screen shots and phone model etc for get help . Any way Try 2 or 3 times again with simple or modified data cable . |
03-30-2015, 17:02 | #27 (permalink) | |
Member: 448639 Status: Offline Thanks Meter: 165 | Quote:
how get authorize file ?????? | |
