AVATOR BOX (China Phones Service Tool) |
07-04-2018, 09:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | ***AvatorPro Ver 2.0 Beta Start*** READ IFNO:- RESET FRP:- LOGS:- Code: Operation : Reset FRP Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM (Android) (COM5) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6737 [MT6737M_S01], SW: 0000, HW: CB00 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100464E58324D42 EMMC CID : 150100464E58324D42 EMMC Vendor: Samsung_FNX2MB EMMC Size : 8GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 512 KiB User Area : 7.28 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Resetting DATA... FRP DATA Found, Reset ok. All Done Operation Done: 00:00:17 Avator Pro SW 2.0 Code: Job Done In 17 Seconds Only...... Br AvatorPro |
The Following User Says Thank You to PUNEET5154 For This Useful Post: |
07-04-2018, 16:39 | #2 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Oppo f3 secure boot reset frp :) OPPO F3 SECURE BOOT RESET FRP FORMAT FORMAT LOGS:- Code: Operation : Reset FRP Brand: OPPO Model: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port (COM67) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6755 [MT6755], SW: 0001, HW: CB00 BL Ver: FE; Indicate: 00000005 Loading boot... INT_SYSRAM_BOOT test completed. Connection type:brom Configuring DRAM... Waiting for DRAM detection...OK Sending 2nd DA ... SYNC... OK 2nd DA...OK Retrieving RAM Configuration ... SRAM Size: 0x40000 DRAM Size: 0x80000000 Retrieving Memory Configuration ... EMMC CID : 150100524836344D4205649BC6C424EF EMMC Vendor: Samsung_RH64MB EMMC Size : 64GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 58.24 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Reading phone info... done. Android6.0 Resetting DATA... FRP DATA Found, Reset ok. All Done Operation Done: 00:00:35 Avator Pro SW 2.0 Br., AvatorPro Team |
07-05-2018, 12:22 | #3 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Samsung E1200Y Sim Lock Remove Done..... LOGS:- Code: Operation : Format / Reset Boot: SC6530 NOR Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM266) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL test...OK ArmBootMode: 6530C00000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6500E Flash: SF_GD27Q64 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 7C Start=0x00700000, Size=0x00100000 Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Auto formatting... Done. Operation Done: 00:00:38 Avator Pro SW 2.0 NO MORE DEAD.SAFE FORMAT AVATORPRO Br AvatorPro |
07-05-2018, 13:11 | #4 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | One more e1200y phone lock done via format Code: Operation : Format / Reset Boot: SC6530 NOR Hint: Power off phone, hold bootkey, Insert usb cable Scanning usb device... Phone found : SPRD U2S Diag (COM266) A thread is created to handle new usb connection, pls wait... Bootstrap: SPRD3 Connected...sending boot... FDL test...OK ArmBootMode: 6530C00000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6500E Flash: SF_GD27Q64 NOR ID : 00C8006000170000 NOR Size : 8MB NOR Name : SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 7C Start=0x00700000, Size=0x00100000 Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Auto formatting... Done. Operation Done: 00:00:50 Avator Pro SW 2.0 Br Puneet5154 |
07-06-2018, 13:59 | #6 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Panasonic eluga i2 privacy lock removed in 9 sec Code: Operation : Remove Privacy Lock Codes Boot: MTK_AUTO Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek PreLoader USB VCOM (Android) (COM5) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6735 [MT6735M_S01], SW: 0000, HW: CA00 BL Ver: 01; Indicate: 00000000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100463732324D42 EMMC CID : 150100463732324D42 EMMC Vendor: Samsung_F722MB EMMC Size : 8GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 512 KiB User Area : 7.28 GiB Boot Completed. Checking userdata encryption... Userdata State : Generic Removing privacy lock ... All done. Operation Done: 00:00:09 Avator Pro SW 2.0 ONE AND ONLY SAFE TOOL AVATORPRO |
