AVATOR BOX (China Phones Service Tool) |
10-29-2014, 18:38 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Elva Cellular - Indonesia
Member: 1386044 Status: Offline Thanks Meter: 65 | Bad result test for SPD 6820/8820 by AvatorBeta_7.126 [problem Solved/Drivers] Condition : Locked by Pattern (sorry, i forget to show picture lock pattern). To: Avator Team Maybe any bug on this beta version cause not supported on cpu SPD6820/8820 Android. If i try to connect always stuck on detected port com only. I'am sure my computer and spd driver 100% worked, cause if i'am use other tool (2 tools) working perfect. sorry i'am not to compare with other tools in here, just wanted to show that this version there is a bug and does not support. I hope the team can fix this bug for a full update. Thank you BR, elvahape This screenshot: |
10-29-2014, 19:13 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: AvatorBox MCU
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | http://forum.gsmhosting.com/vbb/f652...-test-1873897/ for my test phones working... anyway we check again |
The Following User Says Thank You to Avatorbox For This Useful Post: |
10-30-2014, 05:07 | #3 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
this is my test report ***** photo sharing wbr Momin_Telecom | |
The Following User Says Thank You to Momin_Telecom For This Useful Post: |
10-30-2014, 06:23 | #4 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
Hi bro you need to change spd driver for Avatorbox,check this test report ,same cpu and flash id of your phone Working very well . http://forum.gsmhosting.com/vbb/10621845-post21.html Regards amn32 | |
10-30-2014, 11:54 | #6 (permalink) |
Member: 1386044 Status: Offline Thanks Meter: 65 | I am confused, I have done the uninstall / replace spd driver, restart pc but still stuck on the com port only. while other tools can connect. Is my box problem? how to fix it. whereas previously could connect. step that I do like my post here: http://forum.gsmhosting.com/vbb/f652.../#post10085277 Please guide me for fix my box problem. Thank you BR, elvahape |
10-30-2014, 12:06 | #7 (permalink) | |
http://forum.gsmhosting.com/vbb/f652...-user-1865320/ | |
10-30-2014, 14:55 | #8 (permalink) | |
Member: 1386044 Status: Offline Thanks Meter: 65 | Quote:
same result bos, stuck on show port com only. | |
10-31-2014, 04:31 | #11 (permalink) |
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | Actually i seen your post . your computer detects the spd phones . than why not ... in beta we did not make any major core changes to affected the drivers . 1 . Do not use any usb hubs 2. use directly computer usb Port in cpu motherboard ... (means do not use front usb on cpu ) 3. use boot cable or normal usb cable with boot keys sure will work And please tell us . what is the phone Problem ... |
10-31-2014, 06:08 | #12 (permalink) | |
he is put the cable before any operation with battery in the phone | |
10-31-2014, 06:58 | #13 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Before update by shorting + - cable , my AB working fine . Now many spd and mtk phones cant boot at all , i think not only me facing this kind of problem . Please check the complain in forum and help to solved our problem , thank you ! |
10-31-2014, 07:55 | #14 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
Wbr ..:\\lucky//:.. | |
10-31-2014, 17:58 | #15 (permalink) |
Member: 1386044 Status: Offline Thanks Meter: 65 | Thank you to all who have responded to my problem. Especially for bro Momin_Telecom who tried to help with team viewer. Actually the problem is the phone is locked by pattern and has been resolved with the other tools in the same computer, and this proves the setting of the device manager and spd drivers work well. Maybe this is a factor "X" and I will try to find the problem of where. Long time before now my avator working perfect on this cpu, see my posting (http://forum.gsmhosting.com/vbb/f652.../#post10085277). This is also the first phone that I use this beta test. Next time when there is a phone with the same cpu i will be test again and I will post the results. once again thank you for Avator team. continues to move on the hard work the best for our, loyally users of AvatorBox. BR, elvahape |
The Following User Says Thank You to elvahape For This Useful Post: |
