Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 10-29-2014, 18:38   #1 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
Bad result test for SPD 6820/8820 by AvatorBeta_7.126 [problem Solved/Drivers]
Phone Type: i-Cherry C112 (Brand in Indonesia)
Condition : Locked by Pattern (sorry, i forget to show picture lock pattern).
To: Avator Team
Maybe any bug on this beta version cause not supported on cpu SPD6820/8820 Android. If i try to connect always stuck on detected port com only.
I'am sure my computer and spd driver 100% worked, cause if i'am use other tool (2 tools) working perfect.
sorry i'am not to compare with other tools in here, just wanted to show that this version there is a bug and does not support.
I hope the team can fix this bug for a full update.
Thank you
BR,
elvahape
This screenshot:
File Type: jpg Avator_FAILED_CPU6820_8810_Android.JPG (165.3 KB, 114 views)
Old 10-29-2014, 19:13   #2 (permalink)
Member: 1427447
Sonork: 100.1596998
Thanks Meter: 4,218
http://forum.gsmhosting.com/vbb/f652...-test-1873897/
for my test phones working...
anyway we check again
The Following User Says Thank You to Avatorbox For This Useful Post:
Old 10-30-2014, 05:07   #3 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
To: Avator Team
Thank you
BR,
elvahape
This screenshot:
bro driver not detect correctly try again
this is my test report
***** photo sharing
wbr
Momin_Telecom
The Following User Says Thank You to Momin_Telecom For This Useful Post:
Old 10-30-2014, 06:23   #4 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,313
To: Avator Team
Thank you
BR,
elvahape
This screenshot:
Hi bro you need to change spd driver for Avatorbox,check this test report ,same cpu and flash id of your phone Working very well .
http://forum.gsmhosting.com/vbb/10621845-post21.html
Regards
amn32
Old 10-30-2014, 06:28   #5 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
Ok bro, i will check, test and send result soon. Thank you
Old 10-30-2014, 11:54   #6 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
I am confused, I have done the uninstall / replace spd driver, restart pc but still stuck on the com port only. while other tools can connect. Is my box problem? how to fix it. whereas previously could connect. step that I do like my post here: http://forum.gsmhosting.com/vbb/f652.../#post10085277
Please guide me for fix my box problem.
Thank you
BR,
elvahape
Old 10-30-2014, 12:06   #7 (permalink)
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
Thank you
BR,
elvahape
go to this post and download driver install this then post results
http://forum.gsmhosting.com/vbb/f652...-user-1865320/
Old 10-30-2014, 14:55   #8 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
same result bos, stuck on show port com only.
Old 10-30-2014, 15:27   #9 (permalink)
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
contact me any massanger i,ll try to solve your problem
Old 10-30-2014, 15:50   #10 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
Your YM not online bro
Old 10-31-2014, 04:31   #11 (permalink)
Member: 1427447
Sonork: 100.1596998
Thanks Meter: 4,218
Actually i seen your post . your computer detects the spd phones . than why not ... in beta we did not make any major core changes to affected the drivers .
1 . Do not use any usb hubs
2. use directly computer usb Port in cpu motherboard ... (means do not use front usb on cpu )
3. use boot cable or normal usb cable with boot keys
sure will work
And please tell us . what is the phone Problem ...
Old 10-31-2014, 06:08   #12 (permalink)
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
sure will work
Dear sir already help us he use hub and he can not do it
he is put the cable before any operation with battery in the phone
Old 10-31-2014, 06:58   #13 (permalink)
Member: 117956
Thanks Meter: 115
Before update by shorting + - cable , my AB working fine . Now many spd and mtk phones cant boot at all , i think not only me facing this kind of problem . Please check the complain in forum and help to solved our problem , thank you !
Old 10-31-2014, 07:55   #14 (permalink)
..:\\lucky//:..'s Avatar
Member: 1864000
Thanks Meter: 2,893
Nothing is wrong with updater ,you are doing some thing wrong .As we already said check installation settings in device manager for phones driver .Install suitable drivers ,press start button of Avator press boot key of phone , before connecting any phone to computer by usb cable .
Wbr
..:\\lucky//:..
Old 10-31-2014, 17:58   #15 (permalink)
elvahape's Avatar
Member: 1386044
Thanks Meter: 65
Thank you to all who have responded to my problem. Especially for bro Momin_Telecom who tried to help with team viewer. Actually the problem is the phone is locked by pattern and has been resolved with the other tools in the same computer, and this proves the setting of the device manager and spd drivers work well. Maybe this is a factor "X" and I will try to find the problem of where. Long time before now my avator working perfect on this cpu, see my posting (http://forum.gsmhosting.com/vbb/f652.../#post10085277). This is also the first phone that I use this beta test. Next time when there is a phone with the same cpu i will be test again and I will post the results. once again thank you for Avator team. continues to move on the hard work the best for our, loyally users of AvatorBox.
BR,
elvahape
The Following User Says Thank You to elvahape For This Useful Post:
Page generated in 0.29178 seconds with 9 queries
