AVATOR BOX (China Phones Service Tool) |
12-19-2012, 06:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: kerala
Member: 758812 Status: Offline Sonork: 100.1626261 Thanks Meter: 30 | C1000i imei error after formatting with avator box i have G5 C1000 hang problem i make format then phone is ok but imei is currept and i cant write imei direct or in tracker mode plz help me if i write flash with old file then phone coming the same condition here is log Initializing... DA_LIB_VER_5.1.4.3 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=353056928907836 Unable to locate LID, Force write... Lid=0x2_0x0088, Val=53036578642485F5FFFF All done. after this now imei 2 is ok but imei 1 cant write in tracker mode imei not found ??????? plz help me thanks advance regards renjith |
12-19-2012, 07:54 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Reflash this phone with good same firmware and write imei again. Some time good nv file also helps. Regards amn32 Avator box |
The Following User Says Thank You to amn32 For This Useful Post: |
12-19-2012, 09:16 | #8 (permalink) | |
Member: 758812 Status: Offline Sonork: 100.1626261 Thanks Meter: 30 | Quote:
Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: GFIVE_S2423_SG_C1000i_V1.2 | |
12-19-2012, 09:18 | #9 (permalink) | |
Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=6 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CE00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000150000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: GFIVE_S2423_SG_C1000i_V1.2 flash size is 2mb | |
The Following User Says Thank You to renjith_rpr For This Useful Post: |
