Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 03-06-2012, 14:13   #1 (permalink)
:Akintex:'s Avatar
Member: 1383260
Post citycall m9+ sc6600l7 formate failed
Read info i
CPU: SC6600L7 Flash: NOR_M36C0W6050T0
phone problem Emergency . no network, rebuild imei also
what is the solution.
 Initializing...
 DA_LIB_VER_4.0.3.2
 It is sensing the pinout fast...
 RXD=22  TXD=23
 Connecting...
 Connected...sending boot...
 FDL test...OK
 ArmBootMode: 6600700900006A00_00
 Wait for init Commzero Security Engine...
 Done.
 Loading bootloader...
 Done.
 Changing baudrate...
 Set baudrate to 921600 is ok
 Reading phone HW info...
 Read info is done.
 setting the Flash Parameters...
 Settings have been completed!
 Reading FileSystem info...
 FileSystem Version: 0A
 Failed to auto format.
at 40%
Old 03-06-2012, 17:28   #2 (permalink)
FullFlashPak's Avatar
Member: 782530
Sonork: 100.1605589
Try to do "Reset", If this not helps then only way to fix this is by flashing handset with correct flash file, if u don't have a flash file then u need to arrange a similar handset, read the flash from it or post in AvatorBox section request for same flash file with details info and then flash it to your faulty handset,Some phone have h/w issue also.
this problem mostly in hardware.
Regard
AvatorBox Team
Old 03-06-2012, 21:58   #3 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688 Piranhabox
this 90% hardware
check the hardware
In wintesla 3310, what does cobba parrarel failed means brittnee Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 05-18-2001 16:05
complete N3210 service manual in pdf format frfr Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-08-2001 11:02
MCU EEPROM contents: failed phr3ak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 02-12-2001 14:58
Nokia 5110 v. 5.24 Unlock Failed! Cybertooth Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 02-28-2000 14:35
Mti init failed dogbreak Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-22-1999 00:28
Page generated in 0.26092 seconds with 11 queries
