Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 01-08-2013, 06:01   #1 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,225
Easy way to find rx/tx manually of any phone.
How to find rx/tx manually.
Any pinout can be found in 5minutes.
You need to power On phone and measure voltage on test points.
Hardest part here is that battery must be attached, but test points are under battery.
Here I attaching some examples how battery can be attached while you do measurments.
Best result is to use pinfinder cable: one pair of crocodiles you attach to bettery terminals, another pair to battery.
Look for volatges near 2,8 volts, they are tx/rx.
Br.
amn32
The Following 8 Users Say Thank You to amn32 For This Useful Post:
Old 01-08-2013, 06:18   #2 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,926
Good job br your expiriunce
(nice shering)
Old 01-08-2013, 06:43   #3 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,867
copy from infinity team , Do something u r own
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 01-08-2013, 07:36   #4 (permalink)
Registered User
Member: 291029
Thanks Meter: 97
how to find cpu type automatically without opening your phone all phone using Avator box? when looking for rx / tx manual has long been in the know .. thanks
Old 01-08-2013, 07:44   #5 (permalink)
rabindar's Avatar
Member: 1277253
Sonork: 100.1617779
Thanks Meter: 33
Originally Posted by amn32 View Post
how to find rx/tx manually.
any pinout can be found in 5minutes.
You need to power on phone and measure voltage on test points.
Here i attaching some examples how battery can be attached while you do measurments.
Best result is to use pinfinder cable: One pair of crocodiles you attach to bettery terminals, another pair to battery.
br.
Amn32
boss what will be voltage of rx and what will be voltage of tx, is it same or diffrent.
Old 01-08-2013, 07:45   #6 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,225
What is problem here ,If this is copy ,We are here to help users not for any interuption .This is not any exe or soft ,wich will creat problems to any one .Bro. this is only pics tutorial only for help.Any way ,this is not copy from any other source.
Thanks for taking interest in this section.
Regards
amn32
The Following User Says Thank You to amn32 For This Useful Post:
Old 01-08-2013, 07:55   #7 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,225
Usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
Regards
amn32
Old 01-08-2013, 08:31   #8 (permalink)
digicomm's Avatar
Member: 413149
Thanks Meter: 83
good job.keep helping others
Old 01-08-2013, 08:32   #9 (permalink)
damha2nd's Avatar
Member: 908417
Sonork: 100.1604859
Thanks Meter: 204
only avatorbox team the first one who posted finding rx/tx manually. thanks avatorbox team.
Old 01-08-2013, 12:20   #10 (permalink)
..:\\lucky//:..'s Avatar
Member: 1864000
Thanks Meter: 2,892
Very helpfull tutorial again.
thanks
Old 01-08-2013, 16:21   #11 (permalink)
murari-GSM's Avatar
Member: 1538128
Sonork: 100.1613105
Thanks Meter: 197
good job again bro
murari-GSM
Old 01-08-2013, 17:54   #12 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,061
very helpful info,thanks!
Nizda Mobile
Old 01-08-2013, 18:44   #13 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,137
Thanks For Nice Sharing Good Work.
BR.
Arsalan gsm2000.
Old 02-01-2013, 17:16   #14 (permalink)
laxmi kamlesh's Avatar
Member: 1873645
Thanks Meter: 972
its not correct .its working by chance.
its post only for thanks
dont.t copy other. Create own technology
Old 02-01-2013, 17:29   #15 (permalink)
windman8's Avatar
Member: 614801
Thanks Meter: 133
Regards
amn32
FROM THE START OF SPIDERMAN BOX/FROM CRACK TO ORIGINAL IS VERY EASY TO TEST RX TX OF ANY MTK PHONE OR SPREAD.ALL WE NEED IS you need to activate our box we registered but our pasword error.YOU NEED TO HELP US SO THAT WE CAN USED YOURE VERY STRICT SOFTWARE AVATOR BOX.
Page generated in 0.47730 seconds with 7 queries
