AVATOR BOX (China Phones Service Tool) |
05-06-2014, 05:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Exclusive tutorial how to boot and repair coolsand phones by Avatorbox We have launched coolsand in avatorbox .At first time we do not support Auto pinfinder for coolsand .But can be used jig manually for all operations.Not even coolsand ,all mtk ,spd are also works by this method .No need open phone ,you can adjust pinouts by voltage method using pinout exe of Avatorbox.Read care fully and follow all steps .Sure you will get success and can be expert of this method. 1- connect box and dongle to system 2-Press connect, box will show connected to programme 3-Un tick pinout finder 4-Now see bellow pictures and follow steps. Step -1 Step-2 Step-3 Rx/tx points can be 1.2volt and above to 3.8volts minimum volt like 1.3v ca be tx and maximum like 3.0 can be rx point. Starting from 0.8 or 0.7 are cant be used for pinouts. After selecting points ,minimize pinout and go to Avator programe. And press power button of phone just for 2seconds .All done. Result Download pinout exe and paste it in data folder of Avatorbox. https://forum.gsmhosting.com/vbb/****************************/?2j4c947xcnk6djh ..:\\lucky//:.. Last edited by ..:\\lucky//:..; 06-11-2014 at 18:26. |
The Following 7 Users Say Thank You to ..:\\lucky//:.. For This Useful Post: |
05-06-2014, 16:54 | #2 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Elva Cellular - Indonesia
Member: 1386044 Status: Offline Thanks Meter: 65 | I've tried to follow step by step but it still does not work. Is there anything wrong? Thank You BR. elvahape |
The Following User Says Thank You to elvahape For This Useful Post: |
05-10-2014, 00:41 | #4 (permalink) | |
Freak Poster Join Date: May 2013 Location: jln.asem seribu...
Member: 1930745 Status: Offline Sonork: 100.1621645 Thanks Meter: 29 | Quote:
PLEASE GET UP COMING NEW UPDATE With easy connected(MODE COM in new spd),more cpu,more flash ic>>> like avator old version with fast & easy connecting... im wait for this>>> | |
05-10-2014, 10:36 | #5 (permalink) |
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Hi dear friends Get ready for up coming version /exclusive only for Avatorbox Hi all dear friends get ready for our upcoming version of Avatorbox .Download it .All necessory stuff and tutorial is encluded.Video is also available.Exclusive only for Avatorbox users. Download Get ready friends rar Wbr ..:\\lucky//:.. Last edited by ..:\\lucky//:..; 05-11-2014 at 05:46. |
The Following 3 Users Say Thank You to ..:\\lucky//:.. For This Useful Post: |
05-10-2014, 11:51 | #6 (permalink) |
Member: 1386044 Status: Offline Thanks Meter: 65 | Boss ..:\\lucky//:.. AvatorBox-Ver7.126 you use whether it is a test version? When deign please give me a link to get it.......... Thank You BR, elvahape |
05-10-2014, 12:18 | #7 (permalink) | |
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
Wbr ..:\\lucky//:.. | |
05-10-2014, 12:56 | #8 (permalink) | |
Member: 1386044 Status: Offline Thanks Meter: 65 | Quote:
There is one unit in my hand with a locked code. Earlier there were some units but I returned to the owner because Avator not yet support. Thank you BR, elvahape | |
05-11-2014, 20:08 | #11 (permalink) |
Member: 1386044 Status: Offline Thanks Meter: 65 | Thanks to Avator Team especially to Mr. Lucky. This coolsand test report by me: 1. Read Info: OK (see pict_1) 2. Read Flash: OK (see pict_2) 3. Format: Tick Auto Format: Not OK and display a message "Error: failed to get offset". Phone still alive (see pict_3) 4. Format: Untick Auto Format: OK All Done (see pict_4), but it can not continue to restore the original IMEI and display message "Error: failed to get magic code (see pict_5). Phone DEAD 5. Write Flash: OK. rewrite back up file ok (see pict_6) and phone can be revived but still in a locked state. Maybe there is something wrong of me during the process, the flash file is bad or this can to make an analysis, maybe this is a little bug from this beta exe. Thank you BR, elvahape |
05-11-2014, 20:11 | #12 (permalink) |
Member: 1386044 Status: Offline Thanks Meter: 65 | and This pict_6 and file from read flash: Micron_i3_Coolsand_Gallite_BV4_SF_GD25Q32_4MB - Download - 4shared Thank you BR, elvahape |
05-11-2014, 20:27 | #13 (permalink) |
Member: 1864000 Status: Offline Thanks Meter: 2,893 | @elvahape Dont worry brother ,this is test version ,we are working on it ,hopefully all minor bu gs will be cleared .Any way change baud rate and try again ,if not solve need to sold wires on board .And also thanx for test report. Wbr ..:\\lucky//:.. |
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
05-11-2014, 20:48 | #14 (permalink) | |
Ok Bos. Before i post this test report i've been try change baudrate and solder RX TX only without jig (this way make more easy, only show two voltage in pinout voltage), and i get little trick, more accurate to choose RX TX pinout voltage if use battery on phone not from box cable..... BR, elvahape | |
05-12-2014, 11:46 | #15 (permalink) |
Junior Member Join Date: May 2013
Member: 1945011 Status: Offline Thanks Meter: 2 | helo dear mr luky pleaz tel me how can i purchase smart card activation con direct for u box and doungle already me this is my e mail adress [email protected] i wait ur answer |
