AVATOR BOX (China Phones Service Tool) |
05-25-2015, 11:17 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Okara,Punjab {Pakistan}
Member: 578870 Status: Offline Sonork: 100.1625279 MUGHAL MOBILE Thanks Meter: 934 | What You Mean Brother Not Supported SPD Fully Supported & Save On Avator Box No Can Handle This Chip Only Avator Is The Unique Tool Of The World Which Are Doing Without Any Risk. If You Have Any Issue Plz Post Here Info With Screen Shot |
05-25-2015, 13:47 | #6 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
If you need any help Always post here Screen Short / Avator Box Log Other wise we can't Understand We are working very hard for provide World best Solution Always Care Our User Also care your Customer/Your Time/Your Money Wbr Momin_Telecom | |
The Following User Says Thank You to Momin_Telecom For This Useful Post: |
05-26-2015, 11:11 | #7 (permalink) |
Freak Poster Join Date: May 2009
Member: 1036725 Status: Offline Thanks Meter: 31 | The phone is fully working. I wanted to read the firmware. If you try to read the firmware, produces a menu as if the expert mode. From this he concluded that the memory chip is not known.Used v 7.901, v7.902betta. Chip=SpreadTrum Action=ReadInfo FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM22 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00C800BCFFFFFFFF NAND_Size=0MB NAND_Name=NAND_UNKNOWN Initializing... DA_LIB_VER_6.2.0.3 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM21 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Unknow Manufacturer ID, Flash does not exist or failed to initialize H/W. CPU: 88100001 Flash: NAND_UNKNOWN All done. |
05-29-2015, 04:31 | #9 (permalink) |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | It is new flash id if we find this phone will try to add in next update . |
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
